Painting A Bathroom With Oil Base Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 04:49 PM   #1
Painting a bathroom with oil base paint
Hello; I have a bathroom that was painted a few years ago with oil base paint. I cleaned it with tsp solution and it looks pretty good. I want to continue to paint on top with oil base, but it is difficult to find it and the tenants do not like the smell. If I could I would like to paint over with semi-gloss enamel water base. But I am afraid it is going to peel off.
Any advice ? Thanks
Gabriel8642 is offline   Reply With Quote
Old 04-24-2013, 04:58 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
You will need to scruff up the surface some with 100 grit sandpaper, apply a bonding primer( Zinnser 123) then paint
Old 04-24-2013, 09:01 PM   #3
Too Short? Cut it Again!
What Chris said!
In the old days, I would have used an alkyd primer but most are still solvent based and would defeat your purpose. Not really necessary if you are putting a latex/acrylic product over a good bonding primer these days anyhow.
Do use a quality paint store, not box store, semi-gloss. Or for a less institutional look, drop down the sheen to a satin or something less glossy looking. It will still resist the moisture and be easy to clean but will not look like a hospital room.
I assume you have adequate ventilation if it is a small bath via a window or an exhaust fan. Not much will stick for long on anything if you cannot exhaust the humidity in a small space.
Remember it takes semi-gloss and other acrylics with sheen up to 30 days or so to fully cure so try not to scrub the paint too much before then. Two coats will give you the film thickness you want so don't skimp on that.
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 05:49 PM
Bathroom and Trim Paint tev9999 Painting 3 12-07-2012 09:28 PM
Painting tricky Basement walls. What paint should I use? tw1208 Painting 1 10-12-2012 09:07 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
