Painting Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 05:10 PM   #1
Painting Bathroom
We are remodeling our master bath. Right now I am smooth texturing the walls and ceiling to get rid of the stipple finish that was original. We had a new 36" shower installed with granite up to the ceiling on 2 sides, and glass ( not all the way to the ceiling ) on two. I will be installing a fan above the shower, maybe not centered, but towards the door. We would like to stay away from gloss or semi gloss, maybe a satin finish. Will the satin hold up above the shower? Any special needs other than a drywall primer?
Malibujim is offline   Reply With Quote
Old 02-06-2011, 07:12 PM   #2
Super Master Painter
Ole34's Avatar
any type of enamel will be fine...............caulk the grout line that meets the wall and youll be fine...............
Ole34 is offline   Reply With Quote
Old 02-06-2011, 07:15 PM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You will only need to prime if its new drywall or you have made repairs. Any quality latex paint with 100% acrylic binders will hold up for years. My preference would be Sherwin Williams Duration Satin finish. Have used thousands of gallons of it over the years and have never seen it fail.
housepaintingny is offline   Reply With Quote
Old 02-06-2011, 08:54 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Yep, satin is fine.
Old 02-07-2011, 12:21 AM   #5
Professional Painter
Satin/Eggshell would be fine...you need to so some sheen on the ceiling. Read this blog and you'll learn why -
Last edited by Gary in WA; 02-07-2011 at 12:22 AM. Reason: As stated in our Advertising Rules, you may not post advertisements on our site unless your a local contracting professional
mattroefer is offline   Reply With Quote
Old 02-09-2011, 10:41 PM   #6
Just remembered that I have a 1/2 gallon of Mad Dog Primer left from last summer, from painting the exterior of our house. I had got it for priming the stucco near the ground, where the stucco had deterriated and the paint was peeling. Haven't opened it yet to see it's condition. Would this be of benefit to prime the ceiling over the shower ?
Old 02-09-2011, 11:04 PM   #7
Rewards Points: 616
You will only have to prime the ceiling if it is a bare substrate or you have performed repairs.
Painting Bathroom Cabinet-Need Help! Stella1701 Painting 2 08-15-2010 01:02 PM
Painting a SMOKERS Bathroom Greeker Painting 9 06-22-2010 03:08 PM
Painting bathroom in Florida janecon Painting 1 03-27-2010 07:40 PM
painting joint compound in a bathroom AnnaVanLenten Painting 5 10-09-2008 10:14 AM
spackling before painting in a bathroom Woertendyke Painting 7 09-21-2008 11:35 AM
