Painting Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 09:24 AM   #1
Retired
Edgar214's Avatar
Painting Bathroom
I'm remolding my master bath and will take it down to the studs, so all surfaces will be new.
My plan for paint is to prime with Zinsser B-I-N and paint with Zinsser Perma White.
Opinions Please.
Thanks Mike
Edgar214 is offline   Reply With Quote
Old 01-29-2011, 09:54 AM   #2
Good choice.
throw in some 6" crown moulding for some pazazz!
try out the frog tape.
works very nice
Marbledust is offline   Reply With Quote
Old 01-29-2011, 10:21 AM   #3
(the original)
Rewards Points: 756
Opinions Please.
Thanks Mike
Mike, the bug crap is major overkill for new drywall. Perma White is self priming (meaning it has the bonding characteristics of a primer, not to be confused with the "paint and primer in one" box store junk), so you can get away with two coats of PW. That said, though, a good paint job is one coat primer and two coats paint, so I prefer to seal with a coat of Bullseye 123 and top with two coats of PW. If you want to use the PW as it's own primer add a third coat.
While you have it gutted, now's the time to add, check, or replace an exhaust fan, too.
ratherbefishin' is offline   Reply With Quote
Old 01-29-2011, 11:13 AM   #4
Rewards Points: 526
I would use an ordinary latex drywall primer. Two coats. Shellac may work (I don't know), but it is very unpleasant to work with.
Windows is offline   Reply With Quote
Old 01-29-2011, 11:23 AM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Shellac is overkill. PVA Drywall primer is underkill. A standard latex primer will do just fine and then 2 coats of atleast an eggshell paint but satin or semi-gloss is prefered.
Old 01-29-2011, 12:28 PM   #6
Faron79's Avatar
Rewards Points: 260
Yeah...BIN is a fantastic primer, but drywall is waaaaayyy too absorbent.
Use 123, or other "Enamel Undercoater" primer. PVA "drywall" primers are OK, but there are better choices.
If you're FUSSY....apply 2 full coats of 123/similiar, wait a day, then lightly pole-sand the primecoats. You'll have a studly-smooth wall that the paint will show beautifully on.
If you just used a normal drywall primer on 1/2 a wall, and the above process on the rest...you'd see the difference a mile away.
Faron
Faron79 is offline   Reply With Quote
Painting Bathroom Cabinet-Need Help! Stella1701 Painting 2 08-15-2010 01:02 PM
Painting a SMOKERS Bathroom Greeker Painting 9 06-22-2010 03:08 PM
Painting bathroom in Florida janecon Painting 1 03-27-2010 07:40 PM
painting joint compound in a bathroom AnnaVanLenten Painting 5 10-09-2008 10:14 AM
spackling before painting in a bathroom Woertendyke Painting 7 09-21-2008 11:35 AM
