Old 10-19-2012, 10:38 PM   #1
Painting basement walls (Fake wood?)
Hey guys! Finally want to get around to re-doing the basement. All the walls are already covered with what I can only describe as fake wood panels? They are semi-glossy, little rough.. Not sure if really fake or not, might not be due to age of the house.
Anyways, I debating about putting up drywall, but I think if I just paint time white I will save a lot of money with a very close look to what I'm after.
Any suggestions as to paint, primer, steps to be taken? Brand of paint?
I want the basement to feel "bright" should I go glossy-semi-flat?
Cheers!!!
vexious is offline   Reply With Quote
Old 10-20-2012, 06:32 AM   #2
paper hanger and painter
chrisn's Avatar
Lightly sand, clean and paint with whatever floats your'e boat.
Me, I would use Ben Moore Regal eggshell or flat, but since I cannot get it here, Sherwin Williams super paint would do.
No reason for semi gloss on any walls, .............. ever.
Old 10-20-2012, 07:43 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
The most important part of the job is getting whatever hits it first to bond well. I recently did alot of paneling-
Thorough sand- then i used a TSP substitute to wipe on to degloss and remove sanding dust. Then prime with a really good bonding primer.
Zinsser 123, Stix, Smart Prime are good examples.
Then I used BM regal Matte for finish.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-20-2012, 08:03 AM   #4
sdsester's Avatar
If it is a thin vinyl clad siding, just be careful not to sand through the vinyl into the base layer.
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
ltd (10-20-2012)
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Painting wood and walls... Leikela Painting 1 11-23-2009 02:58 AM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
