Old 01-09-2013, 12:06 PM   #1
Painting a basement wall
I'm in the process of painting a basement wall of a home that I intend to sale as an unfinished basement. I need to know if I could get away with a block filler or block coat. I just want it to look nice and clean. I plan on doing the walls in the white filler and the floors in a glossy gray. Should I go with the filler or should I do paint ?
Janice Hawkins is offline   Reply With Quote
Old 01-09-2013, 12:17 PM   #2
cdaniels's Avatar
Paint the walls after they are filled.If it's worth doing then do it right.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Gymschu (01-09-2013)
Old 01-09-2013, 01:04 PM   #3
Gymschu's Avatar
CDaniels is right. Do the block filler first and seal out any moisture, then paint. If you paint the block now, you can never go back and do the block filler. BF does not stick to paint and if it can't get into the pores of the block, it is ineffective against blocking out moisture. The only way I would just do paint is if you have a raised ranch foundation that is ALWAYS dry.
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Leaking Basement Wall MStocks Building & Construction 3 10-29-2009 10:57 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
