Painting A Basement Floor: Just Need It To Be A Little Less Crappy - Painting - DIY Chatroom Home Improvement Forum
Old 04-29-2010, 10:55 AM   #1
Rewards Points: 79
Painting a basement floor: just need it to be a little less crappy
I realize there's a good deal of information out there on this but it all seems to be geared towards making a beautiful almost "finished basement" floor that will last twenty years. They also tend to assume a concrete floor that is in good shape. This floor is concrete that was in rough shape to begin with and painted over. A lot of the paint is peeling. It isn't worth that much effort; it's just a laundry/storage room. We don't need it to be immaculate, just better than it is.
For prep, I plan on scrapping as much of the peeling paint as I can get, sweeping, vacuuming, mopping/scrubbing, rinsing with a hose and sprayer.
-There are a couple pitted areas that I was considering using SLC on just to make the floor easier to sweep. Bad idea? Even if I get all the old paint off the area first?
-There are also a couple bigger pits, maybe an inch around and inch deep that I might try filling in if there's something that will dry enough paint over in 24 hours or so. What should I use?
-I was thinking of using this stuff: http://www.homedepot.com/webapp/wcs/...9&marketID=185
- Water based, doesn't require primer, not too expensive, instructions don't drone on about how perfect the floor needs to be before you apply it. Any opinions on this stuff or other recommendations?
Ptron is offline   Reply With Quote
Caulking concrete basement wall/floor before painting abledsoe Painting 0 01-10-2010 09:43 AM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 12:23 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 07:54 AM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 10:26 AM
