Painting Basement Floor - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-03-2014, 05:51 PM   #16
Rewards Points: 386
Originally Posted by aa7483 View Post
Got it tsp is out . I'll try and locate one of those two. As far as the paint do I need to prime over the old paint? At least over the peeled spots?
Nope…make sure it's clean - sand the rough edges of the existing paint flush with the floor and paint away. Happy painting.
ric knows paint is offline   Reply With Quote
Old 04-03-2014, 06:12 PM   #17
Hvac pro
Rewards Points: 41
Thanks again for everyone's reponses. One last thing in terms of the floor as a whole do I necessarily have to sand the whole floor since is not particularly glossy or can I get away with a good cleaning?
aa7483 is offline   Reply With Quote
Old 04-04-2014, 03:08 AM   #18
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
Just lightly with some 100 or 120 grit, you are just creating a rough surface for the new paint to bond too. Afterwards, you will need to get all the dust cleaned as well.
Old 04-04-2014, 02:07 PM   #19
Hvac pro
Rewards Points: 41
Ok. Will do. I have a pole sander I can go over it with so I don't have to get down with my Palm or belt sander. Unless you think a floor sander in necessary.
Old 04-04-2014, 05:42 PM   #20
chrisn's Avatar
Rewards Points: 236
nope
pole sander will be plenty good
The Following User Says Thank You to chrisn For This Useful Post:
aa7483 (04-04-2014)
Old 04-15-2014, 11:33 AM   #21
Hvac pro
Rewards Points: 41
Ok well I think I went a little overboard with prep. I started sanding and wire brushing the lease paint and certain areas that I didn't think we're loose came up. I got worried so I decided to get some stripper and strip the floor. The paint must have been well adhered for the most part bc areas I tried the stripper on would only come up with a lot of wire brush work. So I got fed up after wasting a whole day and rented a floor buffer with a 15 in diamabrush coating removal wheel. Did a nice job of removing the bulk of the paint. After that I hit the remaining paint spots with a knot cup wire wheel on my grinder. The steps I had to use the paint stripper and lots of elbow grease. Vacuumed then hit the whole floor quickly with a pole sander with 100 grit. Vacuumed again. Tonight I'll give it a good cleaning with dirtex and patch any problem spots. Once it dries I'll hit the vacuuming once more and paint with a 2 part water borne epoxy.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Painting Floor Joists in Basement SS396 Painting 8 10-21-2009 10:38 AM
painting basement cement floor Ranger31 Painting 11 09-05-2009 05:36 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
