Old 12-27-2012, 10:38 AM   #1
Question
Painting Basement Floor
Hello,
So excited to have found this open forum. I have an older home and grew up with a father who can fix and do anything, but didn't pass the knowledge along to me so well. I'm all about DIY but afraid I'll mess things up and it'll cost more to fix once I've screwed up.
It's currently about 30degrees where I live, but I'm a Teacher and it's Christmas break. So only time I have to paint my basement floor. I recently pulled up the carpet, have 3 boys who love to slop around down there and painting it is my best option.
I understand the importance of prepping the floor first. My biggest questions are:
When cleaning floor for prep is broom, vacuum & soapy water good enough?
Is Epoxy water based paint a wise choice?
How many coats needed?
What am I looking at as far as drying time with cold temps.?
Thanks so much!
ckinser3boys is offline   Reply With Quote
Old 12-27-2012, 11:10 AM   #2
Devil Dog
handyman_20772's Avatar
Make sure the floor is completely clean and dry, and at a proper temperature you may need a couple of fans to promote air movement. Some concrete floor paints may require extra steps prior to painting and you should also make sure you don't have any moisture problems in the basement. You will have to take care of this if you do prior to any painting, and as far as using epoxy floor paint for your basement it may be a good choice, check out DryLoc floor paint. Also, add your location, take some pictures and let us know your progress.
handyman_20772 is offline   Reply With Quote
The Following User Says Thank You to handyman_20772 For This Useful Post:
ckinser3boys (12-27-2012)
Old 12-27-2012, 06:26 PM   #3
yup exactly what handyman said. i'd sweep,vac, and then mop the floor really good. there are lots of different paints for different finishes. what time of finish are you trying to achieve? will this be your finished with gloss or are you going to eventually go back over with a new floor covering? in those temps it can 24-36hours for the paint to dry. heaters, fans, and dehu's can speed up the drying time.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
Old 12-27-2012, 06:33 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
All of the above.
I find i have never vac'd enough. Hate to find bits as I'm painting. Vac, wash, vac and then vac.
I like BM's waterborne epoxy reinforced floor paint.
Dries to a hard sort of eggshell (ie not real shiny) finish. Self priming. Dries pretty quick.
read and follow label.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 12-28-2012, 04:37 PM   #5
Matthewt1970's Avatar
The water based epoxies have come a long way. We did a wash kennel for a vet hospital over the summer with some 2 part water based epoxy. Once that stuff dried you couldn't peel it out of our buckets with a jackhammer. I would be hesitant to put it on a floor without a sand/traction additive.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
ckinser3boys (12-28-2012)
Old 02-08-2013, 02:10 PM   #6
Grants Painting's Avatar
Originally Posted by ckinser3boys View Post
Hello,
Thanks so much!
Read these two articles for everything you need
Last edited by Gary in WA; 02-09-2013 at 05:40 PM. Reason: removed links per forum rules.
Grants Painting is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Vapor barrier & insulation for basement floor dvsanfor Flooring 5 09-26-2010 11:01 PM
Painting Floor Joists in Basement SS396 Painting 8 10-21-2009 10:38 AM
painting basement cement floor Ranger31 Painting 11 09-05-2009 05:36 AM
