Painting Basement: Drylock Over Drylock - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 01:33 AM   #16
Originally Posted by GBR in WA View Post
Did you try tape and plastic on the wall over the mold to see if it is leaking and you don't know it because it evaporates right away from the moving basement air? Whew, I'm tired, it's late....LOL. Mold needs moisture to grow, the wall may be wet unless it's Summer mold, the interior wet air going out.... Point being, I'd use a latex based paint to allow the wall to dry when left uncovered from insulation. Drylock will force any outside water to find an alternate route in to your space using the next easiest place, slab, etc.
Gary
Gary, if you don't mind, I'll finish your excellent point. OP, do vapor test. Take a piece of plastic about one foot sqaure and tape it to the wall, seal it tight on all four sides, wait a couple of days. If there is condensation on the plastic your getting moisture through the walls. Good point Gary.
Old 03-30-2011, 09:34 AM   #17
Originally Posted by Matthewt1970 View Post
Drylock, Masonry Paint/Primer and Block fill are only good on bare block. They are meant to expand somewhat and fill the voids. They are basicly useless in that aspect once paint is on the walls.
Ok. Yeah, I thought I had heard that before. You can clearly see that they painted it over old paint but what's done is done.
Ptron is offline   Reply With Quote
Old 03-30-2011, 09:47 AM   #18
Interesting. Does it matter that it hasn't been particularly rainy or humid out the last few days? IIRC there was a little bit of mold along the bottom of the walls that I bleached off when I moved in. It hasn't come back and that was a year and a half ago.
BTW, I mentioned getting water in the OP. This only happens after prolonged periods of heavy rainfall. It only comes in at the base of the wall (on the opposite side of the house that the picture was taken) and even at it's worst has been manageable amounts.
Water coming in at base of foundation
Old 03-30-2011, 11:23 AM   #19
Ptron, water coming in during rain and moisture transfer can occur simultaneously. It's like a leak in the roof, even during a light rain, the leak is drawing water, it's just being absorbed by the substrates inside the leak. When it rains hard they get saturated, overflow, and it comes through the ceiling. I would at least test first before you paint because if moisture is transfering through the foundation, your efforts will be in vain, at least in the area of the breach.
Old 03-30-2011, 11:34 AM   #20
Thanks. I'll give it a try.
Insulating basement - questions jtmann HVAC 7 11-19-2010 04:20 AM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 09:26 PM
Caulking concrete basement wall/floor before painting abledsoe Painting 0 01-10-2010 10:43 AM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
