-   -   Painting basement: Drylock over drylock (http://www.diychatroom.com/f4/painting-basement-drylock-over-drylock-99941/)
Ptron 03-29-2011 11:45 AM
I would like to paint my basement before I set up my workshop so it's not so depressing. The current finish looks like might be a half-fast application of drylock over old paint. I've never noticed water coming through the walls before. Whether this is because the drylock is actually doing something or it wasn't a problem in the first place, who knows? Anyway I was thinking of painting it with drylock just for good measure.
-Is it in any way a bad idea to use drylock "just for good measure"?
-Can I just paint drylock over the old stuff or does it still need to be primed?
-If drylock is a bad idea (or just a waste of money) should I use exterior primer and paint?
-Is anti-mold/mildew paint worth it? I don't have a big water or humidity problem down there but I do get a little bit of water a couple times a year.
http://i209.photobucket.com/albums/b...nius/BSMNT.jpg
NCpaint1 03-29-2011 03:25 PM
Go to a paint store and get "Block Filler". Its just a really thick paint that fills in the pores of the block better. Its cheap too, but the spread rate is less.
chrisn 03-29-2011 05:25 PM
Be prepared to be exhasted when done, this stuff is HEAVY, but you really cannot apply dry lock over any other finish, so block filler shoud do what you need.
Ole34 03-29-2011 05:31 PM
i would get the cheapest enamel you can find an do 2 coats .....use a heavy nap roller cover......that block you have is already painted so painting it again is gonna be a cake walk......... go with something with a high spread rate and youll be done in no time ...............
Ptron 03-29-2011 05:36 PM
Thanks for the suggestions. Cheap...I like the sound of that.
jsheridan 03-29-2011 07:26 PM
Is anybody going to address the water stain problem. Block filler won't do it. You need to oil prime, Zinsser Cover Stain, the water stain. Have some serious ventilation or extinguish the pilot lights, that's a possible kaboom. Nothing is going to stop that moisture from coming through though, the drylock that's on there is no longer enough, and you can't, as ChrisN said, put drylock over any other finish, even drylock. Add some mildewcide to the finish and put a humidifier in the basement. It looks like you already have some mildew there, wash with bleach/water and rinse.
Ptron 03-29-2011 09:09 PM
My appologies. I was going to say something in the original post but forgot. I Included that picture mostly to show how spotty the dry-lock (or it could be block filler) was applied. That stain along the bottom looks in the picture like it's from water coming through the foundation but up close you can see it's from something that was splashed or spilled on there from the inside. Who knows from what, a dirty mop or something. The corner looks darker mostly from the lighting but als the coating is spottier/thinner there.
Ptron 03-29-2011 09:36 PM
Sorry if this is a rudimentary question but when you say enamel, you mean as in oil based right? When I used to paint apartments years ago. We said "enamel" and "latex" to mean "oil based" and "water based". But then you see a lot of water based paints that say enamel.
Ole34 03-29-2011 09:38 PM
sorry bout that .....latex enamel is what i meant
jsheridan 03-29-2011 09:43 PM
I'd be hardpressed to believe that something on that wall isn't going to burn through a latex coating. Paint it out with latex and if anything comes through, spot it will oil and then the finish.
Ptron 03-29-2011 09:44 PM
Thanks. That was fast!
Ptron 03-29-2011 09:45 PM
Wow! Rapid fire responses. Much thanks. I will do that.
Ole34 03-29-2011 09:49 PM
no problem, its our job here..............good luck with your basement !!
Matthewt1970 03-30-2011 12:52 AM
Drylock, Masonry Paint/Primer and Block fill are only good on bare block. They are meant to expand somewhat and fill the voids. They are basicly useless in that aspect once paint is on the walls.
Gary in WA 03-30-2011 01:15 AM
Did you try tape and plastic on the wall over the mold to see if it is leaking and you don't know it because it evaporates right away from the moving basement air? Whew, I'm tired, it's late....LOL. Mold needs moisture to grow, the wall may be wet unless it's Summer mold, the interior wet air going out.... Point being, I'd use a latex based paint to allow the wall to dry when left uncovered from insulation. Drylock will force any outside water to find an alternate route in to your space using the next easiest place, slab, etc.
Gary
