Old 08-29-2009, 05:49 PM   #1
Question
painting basement cement floor
My mother want the basement floor in her house painted.
The floor has never been paint, but has all kinds of stains on it, beside
the usual traffic dirt.
I seen cement floors paints else where, but later I notice the porch gray
paint peeling off.
Also I would need to paint it in steps. Let one painted area dry then move
stuff, back to where I just painted. I want it to be a long lasting, sealing type paint.
Please help me, I am clue less, as to how to start this project.
THANKS
Ranger31 is offline   Reply With Quote
Old 08-29-2009, 09:13 PM   #2
Painting Company, NY
housepaintingny's Avatar
First test the floor to make sure there are no moisture issues, because if there are you'll have to resolve that first otherwise you'll have paint failure no matter what you use. Tape a 2foot square piece of plastic down onto the floor taping all sides tight. Leave it for 48 hours, check it for discolouration in the floor, moisture laying under the plastic or on the plastic. If all is well after that then you'll have to clean the floor well. A good product for that is ProClean Professional from Sherwin Williams, next fill any cracks and fix any deteriation with a product like armorseal from Sherwin Williams, now decide if you want to paint it or stain it with a concrete stain like H&C, which you can get from Sherwin Williams, there about 100 colors to choose from, it applies like paint, and you can seal it with a sealer coat in your sheen choice. If you go with paint Sherwin Williams heavy duty porch and floor paint will work well. I am not a SW sales man I am a painting contractor in NY and usually only use SW products, I've always had good luck with them. There are a lot of good product choices, but the proper preparation goes a long ways to prevent paint failure.
housepaintingny is offline   Reply With Quote
Old 08-30-2009, 06:50 AM   #3
paper hanger and painter
chrisn's Avatar
I would not put this or any other paint that was not specified for garage floors down, as the hot tires will lift off any normal paint.
Old 08-30-2009, 09:04 AM   #4
If you'll be driving a car on the floor a concrete stain will work or if you want to paint it you need an epoxy based concrete floor coating like shield-crete, also from H&C concrete, Sherwin Williams
Old 08-31-2009, 10:02 PM   #5
I will not be driving a car over this cement floor.
It is a cellar floor. No garage door.
But I like the idea's that have been suggested.
But can I paint in stages? I don't want to
empty out the who cellar.
Also is fall the best time of year for this
type of project.
Old 09-03-2009, 03:10 PM   #6
NAV
I say do not paint it.
Hydrostatic pressure
They sell cleaners that will take out the stains. Look up Klenstone or Prosoco
NAV is offline   Reply With Quote
Old 09-03-2009, 08:53 PM   #7
what would you use to to stop cement dust, coming from the floor.
THANKS
Old 09-04-2009, 03:54 AM   #8
chrisn's Avatar
rug?
Old 09-04-2009, 06:13 AM   #9
left my self why open for that one.
Old 09-04-2009, 07:00 PM   #10
chrisn's Avatar
What do you mean cement dust?
Old 09-04-2009, 09:46 PM   #11
Cement dust, is the Lime working it way out the cement, then it just sit
on the surface, until you sweep or vacuum it up.
This way, my mother want the cement floor paint of seal, to stop this.
Old 09-05-2009, 05:36 AM   #12
chrisn's Avatar
http://www.appliedtechnologies.com/h...te_sealer.html
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
Laminate on Basement Cement floor... helpless handyman Flooring 12 02-19-2009 04:33 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
Basement Floor Drain amazinlittledevil Plumbing 8 01-04-2007 02:17 PM
