Painting Bare Steel- Sand First Or Use Etch Primer? - Painting - DIY Chatroom Home Improvement Forum
Old 10-11-2007, 04:00 PM   #1
Painting Bare Steel- Sand First or Use Etch Primer?
I have a steel pole that I need paint a gloss black, for use as an outdoor sign. Right now, it is bare steel with a coating of grease on it. My plan so far is to use turpentine to remove the grease, put on a coat of primer, and then finish with 2 or 3 coats of gloss black acrylic paint. However, I've been reading something about using an etch primer on steel. It's supposed to make it easier for the primer to hold on to. I was also reading about sanding the surface first before the primer for the same reason. Any suggestions on what to do? I'm not sure if I should use etch primer, then regular primer, then black paint, or to sand the surface first, then use regular primer, then black paint.
scott890 is offline   Reply With Quote
Old 10-11-2007, 04:41 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
I used to paint bicycles. I used a etching primer and followed by several coats paint, and then several coats of clear.
I would quiz the guys in an auto paint store, they will have the answers. Are you painting this with spray cans or do you have a spray gun?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-11-2007, 05:32 PM   #3
I'll be using spray cans.
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
