Painting Around A Chair Rail - Painting - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 10:40 AM   #1
painting around a chair rail
Hello,
I have white chair rail in my living room, didning room, and family room. I would really like to change the wall color. Do I need to remove the chair rail before I paint or can I just tape off the chair rail?
Annie81 is offline   Reply With Quote
Old 02-29-2012, 11:43 AM   #2
Rewards Points: 12,828
Faster, cheaper and less mess to just use a 2-1/2 quality sash brush and paint around it without the tape.
If I did tape it I would use 2" wide tape only on the top of it and do not press it down over the face of the rail. It will act as sort of a tent to prevent paint drips as your rolling the wall.
Along the bottom I'd skip the tape.
Reason being far to often the tape peels off the paint under it as your removing it making more work, It also almost never completly seals off the area or is miss aligned and you will not see the bad spots untill it's to late.
With the sash brush you can see what your doing as you go. If you get some paint on the rail you can just ripe it off and touch it up as you go.
Old 02-29-2012, 02:01 PM   #3
Thank you so much, sounds like great advice. Wish me luck!
Old 02-29-2012, 04:13 PM   #4
Too Short? Cut it Again!
Make sure you use a quality angled sash brush. Expect to pay $15-18 retail. With a bit of practice you will almost be able to pinstripe with the edge of it. It will last a long time if you take care of it. Purdy and Wooster are the brands I usually bought.
Now is the time to caulk---before you paint---as well if there are any gaps showing between the chair rail and wall.
Painting walls two colors as split by a chair rail Magraloo Painting 13 01-28-2015 06:23 PM
Installing chair rail over uneven sheetrock krazykarr Drywall & Plaster 10 12-20-2011 12:51 AM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
Unique Chair Rail Obstacle mormegil Interior Decorating 4 06-03-2011 07:56 PM
Painting baseboard molding same color as chair rail and crown molding Barb Wieczynski Painting 4 04-11-2009 09:32 AM
