Painting Antique Brass Fireplace Trim To Satin Nickel? - Painting - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 08:01 PM   #1
Painting antique brass fireplace trim to Satin nickel?
I'm doing some updating and our fireplace has very nice custom glass doors. Thing is the trim around it in antique brass. Its not smooth brass its bumpy like a hammered look. Any thoughts on painting it with a rustolium hammered nickel paint? Is there maybe a better way to do this? I like the doors just not thee color of that trim. Thanks
mommiemara is offline   Reply With Quote
Old 08-28-2011, 03:14 AM   #2
m1951mm's Avatar
Rustoleum hammered finishes are one of my favorites. I have not seen it in nickel. Gray and silver yes, but not nickel. You mentioned satin nickel which is a smooth finish. I do not believe you can achieve a smooth finish working over a textured finish as you have now, plus if you use the hammered finish it has particles in it that create the hammered look.
I prefer to use the spray, two light coats covers well. Are you able to do this outside?? Protect the glass with tape and plastic, spray, wait for whatever time the label tells you before handeling and then reinstall. I have not used the brush on product but as long as you apply two THIN coats you should be good to go.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 08-29-2011, 02:46 PM   #3
Whenever you are dealing with spray painting metal like that, take the time and the little bit of extra money and buy a good primer. Primer / preperation is the key to any good paint job. Good Luck
The Design Duo Blog
DesignDuoBlog is offline   Reply With Quote
Painting cira 80"s rough interior trim PGirl Painting 5 08-20-2011 09:23 PM
Painting stained trim and doors noone Painting 38 08-13-2011 04:44 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
Where can I get satin nickel door knobs/levers for a good price? ConstantChange Remodeling 1 10-29-2006 11:03 AM
painting walls w/oak trim THEBIGPUNN Painting 3 04-25-2006 02:28 PM
