Painting An Aluminum Storm/screen Door - Painting - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 09:20 AM   #1
Rewards Points: 150
Painting an aluminum storm/screen door
Good morning,
I want to re-paint an aluminum storm/screen door. The original door was brown aluminum, and it was painted white a few years ago. The paint has started chipping, and I'd like to give it a fresh coat. I plan on removing as much of the paint as possible, mostly by scraping it off with steel wool, or a plastic spatula of some sort.
My question is, what kind of paint should I buy? Should I try and get a metal paint (like a Tremclad) or an oil or water based paint?
All feedback is greatly appreciated!
James
sbmfj is offline   Reply With Quote
Old 09-24-2010, 10:06 AM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Personally when we paint anything that's aluminum, siding, gutters, down spouts, doors, etc. We use a quality 100% acrylic latex, because that will not become brittle like an oil base and chip, it will also withstand more heat than oil, retain color longer, and not become chalky like an oil base paint. The important thing when painting anything aluminum is to clean it well removing any powder and/or chalkyness which is the aluminum that has become oxidized, use tsp or similar product, clean, rinse, prime any bare spots of aluminum with a bonding primer such as a DtM bonding primer (direct to metal) then apply two coats of a quality acrylic latex, also lightly hand sand the aluminum prior to cleaning.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
sbmfj (09-24-2010)
Old 09-24-2010, 10:13 AM   #3
Rewards Points: 150
Thanks for the great response!
Whats a TSP cleaner? any suggestions for a good DtM bonding primer?
Old 09-24-2010, 10:28 AM   #4
Rewards Points: 616
TSP is trisodium phosphate, it is a common cleaner for paint prep. You can find it in any paint store, We always use Sherwin Williams DTM bonding primer
sbmfj (09-24-2010)
Old 09-25-2010, 10:11 AM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Rub your finger on the door. If the color comes off and is chalky, you need Emulsa-Bond. That is an additive you put in your first coat of paint.
painting exterior door JP79ST Painting 18 05-18-2010 04:04 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Entry Door Size han Building & Construction 5 08-20-2009 07:54 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
Help with painting an interior door Kim Painting 2 03-05-2005 12:38 AM
