Painting Aluminum Soffit - Painting - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 10:26 AM   #1
Painting aluminum soffit
My aluminum soffit is 27 years old and has many oxidation spots.
I have wiped the entire house soffits with water and scrubby pads which took off cobwebs and oxidation buildup but once dried out, they still look like oxidation spots. Plan to prime and paint with sprayer. Is there anything else that should be done to the soffits? Will the sprayed paint seal off the ventilation holes?
sojo972 is offline   Reply With Quote
Old 04-25-2011, 07:35 PM   #2
Gymschu's Avatar
Rewards Points: 846
So far good prep work. Sometimes we sand the soffits if there are raised areas of oxidation that don't come off with an initial cleaning. Spraying should not close up the vent holes........sometimes if you brush and roll, you can close off the holes.
Tags
painting , soffit repair
Painting aluminum siding cherry_560sel Painting 27 04-25-2011 01:35 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Painting Aluminum dozen Painting 4 04-10-2009 04:18 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
