Painting Aluminum Siding - Painting - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 02:12 AM   #1
Painting aluminum siding
Sometime this summer I will be painting the exterior of my home. The house is covered with aluminum siding. The paint is chalked and there are bare spots where there is only a minimal residue of old chalky paint covering the area. In short, the siding needs a new coat of paint really really bad. So here's my plan: Take the time to clean the aluminum siding properly (brush, TSP, and lots of hard work), fill small dents with metal filler (bondo), use an oil based primer, followed by a 100% acrylic latex paint. My concern is that after reading many post I have begun to doubt my choice of using the Valspar brand of paint. I plan on using an airless sprayer for the job. My main question is, given that I will be using a primer tinted 50% to the final color, will using Valspar give me good results considering the medium it will be applied to? The siding has a "faux wood grain" and looks like it can go for at least ten more years. BTW, I have peaked underneath the aluminum siding and the clapboards underneath look like they are in awesome shape given that they were last painted over 60 years ago.
cherry_560sel is offline   Reply With Quote
Old 04-19-2011, 06:25 AM   #2
Sounds ambitious, also sounds like you have a good handle on it. My only question is why the oil primer? My concern is the temp fluctuations and the fact that oil won't flex that well on metal under hot Texas sun and cool nights. Personally, I would spot prime any exposed aluminum and two coat with finish. I would go with a Ben Moore system, they have a latex primer that will handle the exposed aluminum and their Moor line of exterior paint has excellent adhesion qualities. The Moor products will grab on to that with a death grip, and with spray the siding will look factory finished. I'm sure the other top manufacturers have comparable systems but my experience is with BM, and I wouldn't recommend anything but the top line products on exteriors. If you can carry the extra cost, the results and peace of mind will be worth it.
The Following User Says Thank You to jsheridan For This Useful Post:
ltd (04-23-2011)
Old 04-19-2011, 06:52 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
1) Aluminum does not like oil. After you prep prime with a 100% acrylic primer like Zinsser 1-2-3. If you still have any chalking issues, use Zinsser Peelstop instead to bind any residue.
2) Use a higher quality paint. Nothing in the big box stores is all that great. Ben Moore, Sherwin Williams, Pratt and Lambert, etc. will all have better products at a comparable price.
poppameth is offline   Reply With Quote
Old 04-19-2011, 06:54 AM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You do not need oil base primer. I would use a latex base primer and you only need to prime the areas that have raw aluminum. I prefer to use SW DTM Bonding Primer and SW SuperPaint, saitn when painting aluminum siding. You will need to apply 2 coats of a quality 100% acrylic latex paint. Sounds like you have a handle on the cleaning aspect of the siding.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
ltd (04-23-2011)
Old 04-19-2011, 07:17 AM   #5
Gymschu's Avatar
Rewards Points: 240
Great advice as always! A side note: You don't use a whole lot of paint on aluminum siding............so splurge a little and put something good on it like the above mentioned SuperPaint. There are some aluminum sided houses I painted 15 years ago that look almost as good as the day it was put on.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
housepaintingny (04-19-2011), ltd (04-23-2011)
Old 04-19-2011, 03:16 PM   #6
Well, from all the research I have done for this project, I keep reading over and over that the primer should be an oil based product due to the fact that an oil based primer will adhere better to the chalky finish. I scrubbed a small area on the corner of the house to see exactly how the cleaning aspect will proceed and after it dried I could still rub off paint with my hand. Also, I have read that an oil based primer does not contain the amonia that the latex primers do. Supposedly, over time, this will react with the aluminum causing it to oxidize and creates air bubbles that rise underneath the latex top coat. I just don't want to take the chance of that happenening. The siding is far past the point of being able to spot prime. What I am most concerned about is the paint that I will be using as topcoat. Like you say, you have experience with BM paints. What exactly is the difference when it comes to all the different brands. They all seem to cost about the same per 5 gallon buckets and from reading the specs they seem to be comparable, but I have been reading on this forum alot about staying away from Behr or Valspar paints and I would like to know what makes them so bad compared to the other brands.
Old 04-19-2011, 03:25 PM   #7
Rewards Points: 616
The chalkyness, which is from oxidation of the aluminum breaking down should all be washed off prior to painting. You will only have to prime any bare aluminum and use a quality latex bonding primer. Then apply a quality acrylic latex paint. Aluminum siding expands and contracts a lot and also conducts heat an acrylic latex can resist heat more and also expand and contract, where a oil base won't.
Old 04-19-2011, 04:29 PM   #8
Gymschu's Avatar
Rewards Points: 240
Cherry, been doing this painting thing for over 30 years. Tried the oil-base primer for aluminum ONCE. Pain in the butt to use, dried poorly on the aluminum, and left me with a less than desirable base coat for my topcoats. Have used latex primer on bare aluminum and topcoated with SuperPaint on many aluminum sided homes. Have never, ever had a problem with peeling or bubbling paint. The only issue I see is that some colors fade after 7 or 8 years.
Old 04-19-2011, 05:35 PM   #9
NACE Coating Inspector
mustangmike3789's Avatar
i would use Sherwin Williams DTM wash primer with two coats of of DTM primer/finish. this system is extremely durable and covers very well. the wash primer only needs to be applied at .7 mils dry film thickness, so it will cover over 300 sqft per gallon. we use this coating over aluminum and galvanized steel in corrosive marine enviroments with no failures. it may be close to the BM product mentioned earlier.
mustangmike3789 is offline   Reply With Quote
Old 04-19-2011, 11:23 PM   #10
Cherry, if you're concerned about residual chalkiness after washing, you can get some Emulsa Bond, which helps latex bond to chalky surfaces. Without getting too technical, higher quality paints use higher quality raw materials. Cheaper eggshells have less sheen because they use lower grade resins, higher grade paints use titanium dioxide as pigment to hide while lower grade paints use basically chalk and clay, etc. The list goes on and on through color retention, sheen retention, durability, etc. You do get what you pay for when you purchase premium paints. How hot do you think that aluminum siding gets when the air temp in Texas is over 100 degrees, probably close to 150 (I'm not a scientist, but I've gotten burned on siding once or twice) Then, what's it go down to at night. Aluminum siding is very thin and that's a lot of expansion and contraction, in my opinion, for an oil to handle. The oil will bond to the surface, but the stress will break that bond. I don't know about the ammonia issue you mentioned. SW makes a primer specifically for non ferrrous metal, aluminum included, so I'm sure that if an ammonia reaction was possible they'd have learned that and adjusted the formula. You've got probably 100+ years experience advising you on this thread to not use oil. We're here to help you get your job done properly, trust us.
Here is a link to mustangmike's reference http://protective.sherwin-williams.c...3Aproduct-6787
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
ltd (04-23-2011), mustangmike3789 (04-22-2011)
Old 04-20-2011, 02:46 PM   #11
Matthewt1970's Avatar
Rewards Points: 1,098
Yes. Use Emulsa Bond. Wash off as much of the chalk as you can but nothing will get it 100%.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
jsheridan (04-20-2011)
Old 04-23-2011, 01:53 AM   #12
,,,ok, and your signature says ...Latex primer, good for drywall. that's about it......sorta gives me pause. So what is the opinion of Valspar duramax acrylic paint? has anyone here used it before?
Old 04-23-2011, 02:19 AM   #13
Valspar is better than Behr but not much. Get some real paint from a real paint store. Pittsburg, Benjamin Moore, Sherwin Williams are my top choices. If you do happen to have some bare alluminum then a bonding latex primer would be ok. I am at odds with housepaintingny about oil not expanding and contracting and heat, we have been using oil based paint for over 100 years and it has been expanding and contracting all along. Other than that he is spot on with his advice.
Old 04-23-2011, 02:20 AM   #14
Half the battle has been won, he's at least considering latex primer. Don't listen to Matt's sig. IMO, latex primers are far superior to oil in some respects, and I'm partial to oil. It's especially true with the characteristics you need, flexibility and bonding. I'm not familiar with your choice, so can't comment. I would suggest seriously considering Mustang Mike's rec of SW DTM (Direct to Metal) wash primer. The man is a certified coatings/corrosion inspector, so I'll take his word on it. It may be a little pricey, but the entire success of the job rests on the primer. My only question for Mike would be
Will it bond and stay bonded with expansion and contraction of siding?
Will it be flexible enough? Kind of related questions.
Old 04-23-2011, 02:49 AM   #15
Just consider this. If you have a 12' bord, which is about the longest you will find on a home, here is your Coefficients of Expansion for wood.
0.0000027 Coefficient of Expansion in inches of expansion per inch of material per degree F. Lets take 100 degree swing.
0.0000027 x 100 Degrees = 0.00027 inches of expansion per inch of material
0.00027 x 144" = 0.0388 inches per 12 feet of board.
If oil based paint can't handle .0388 inches of expansion in 12 feet of wood then I will eat my whole hat.
Nothing Under Aluminum Siding dkel22 General DIY Discussions 9 09-30-2009 04:40 PM
Painting aluminum siding but on inside of room Miguel&Dawn Painting 2 09-07-2009 08:57 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
