Painting After Wallpaper Removal - Painting - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 08:35 PM   #1
Painting after wallpaper removal
I have removed the wallpaper in my kitchen and slo scraped as much of the paste as I can. There is very little remaining and I'm trying to figure out what my next step should be. I hve read that I should clean the walls with TSP before priming but I have also read that you can just use Gardz to seal in whatever is left of the paste. I would rather not use the TSP if I can just use the Gardz. Also, there are a couple of large cracks and other spots that have been repaired with joint compound prior to the wallpaper application. I'm afraid that if I just use the Gardz and then paint over it that the large joint compound spots will show through. Should I texture the walls or is there another way to ensure that you won't be able to see the repaired spots. There are also a couple of places where the old paint is flaking off like in a corner and I was wondering if the Gardz will help seal that and keep it in place. Thanks in advance for the help.
tab13 is offline   Reply With Quote
Old 10-02-2010, 09:14 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
If the repairs don't need sanded to make smooth, just prime all with the Gardz and apply you're 2 finish coats. The patches will disappear. You really should get as much of the paste off as possible by spraying with hot water and maybe using a green pot scrubbing pad
Old 10-02-2010, 12:27 PM   #3
^^^^ Absolutely. Keep scrubbing until all that slime is gone. Sometime a mixture of vinegar and hot water helps. You'll likely have to repeat mutliple times until it's all gone.
hennyh is offline   Reply With Quote
Old 10-02-2010, 06:50 PM   #4
dubinpainting's Avatar
The steps above are good but the chiping paint in the corner you might want to scrape the area free of flaking paint and fill with durabound or joint compound sand then paint.
dubinpainting is offline   Reply With Quote
Wallpaper Removal Choices in Kitchen LeviDIY Painting 14 12-02-2011 04:30 AM
painting and wallpaper residue jayoshi Painting 1 09-13-2009 06:03 PM
Wallpaper Removal saggdevil Painting 1 06-01-2009 05:31 AM
Painting after Wallpaper removal? FixitMyself72 Painting 6 04-20-2009 05:43 AM
OOOLD wallpaper and painting Tab1975 Painting 7 04-07-2009 06:49 AM
