Painting After Wallpaper Removal? - Painting - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 06:43 PM   #1
Question
Painting after Wallpaper removal?
I just recently removed wallpaper from my son bedroom. Everything went fine untill the paint they wallpapered over started to peel off from the chemical used to remove it. The walls are plaster, it's an older home by the way. I know I have to wash the rest of the glue off to give me a good primer surface. What do I do with the areas where the paint is peeling off? Sand, Scrape?
FixitMyself72 is offline   Reply With Quote
Old 04-18-2009, 11:00 PM   #2
Rewards Points: 160
I personally would redo the wall properly...sand it down and restart!
hellothere123 is offline   Reply With Quote
Old 04-19-2009, 12:24 AM   #3
Thats what I was afraid of ! Thanks much for the reply now I am going to get a sander!!
Old 04-19-2009, 02:24 AM   #4
Title 24 Consultant
Sand it down and completely repaint it the is the best way if you want to achieve a good and quality paint on your wall..
AllenB is offline   Reply With Quote
Old 04-19-2009, 10:35 AM   #5
Thanks for all your help guys much appreciated!!
Old 04-19-2009, 02:25 PM   #6
Rewards Points: 506
You may also want to coat with Gardz after you get the failing products off the wall. Gardz can "lock down" wallpaper glue.
And no, I don't work for Zinsser.
sirwired is offline   Reply With Quote
Old 04-20-2009, 05:43 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
I wish I did work for Zinsser
Wallpaper removal and lead paint risk? rhena Painting 12 06-07-2011 05:30 PM
OOOLD wallpaper and painting Tab1975 Painting 7 04-07-2009 06:49 AM
Painting over wallpaper RussellF Painting 8 11-01-2006 02:42 PM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 06:41 PM
