-   -   Painting after Wallpaper removal? (http://www.diychatroom.com/f4/painting-after-wallpaper-removal-42731/)
FixitMyself72 04-18-2009 05:43 PM
I just recently removed wallpaper from my son bedroom. Everything went fine untill the paint they wallpapered over started to peel off from the chemical used to remove it. The walls are plaster, it's an older home by the way. I know I have to wash the rest of the glue off to give me a good primer surface. What do I do with the areas where the paint is peeling off? Sand, Scrape?
hellothere123 04-18-2009 10:00 PM
I personally would redo the wall properly...sand it down and restart!
FixitMyself72 04-18-2009 11:24 PM
Thats what I was afraid of :(! Thanks much for the reply now I am going to get a sander!!
AllenB 04-19-2009 01:24 AM
Sand it down and completely repaint it the is the best way if you want to achieve a good and quality paint on your wall..
FixitMyself72 04-19-2009 09:35 AM
Thanks for all your help guys much appreciated!!
sirwired 04-19-2009 01:25 PM
You may also want to coat with Gardz after you get the failing products off the wall. Gardz can "lock down" wallpaper glue.
And no, I don't work for Zinsser.
chrisn 04-20-2009 04:43 AM
You may also want to coat with Gardz after you get the failing products off the wall. :thumbsup:
I wish I did work for Zinsser:whistling2:
