Old 02-01-2009, 08:20 PM   #1
Painting after wallpaper
I posted a while back about painting my bathroom after removing the wall paper that was in there. I am almost done stripping the paper! What a job that was, the top layer came off and then the paper layer and then this layer of glue to get it down to primer. I even bought a steamer to help and it worked good but still took time to get everything off.
Anyway now that is almost down I'm going to be skim coating it, from what I've read I just mix some mud real thin and use a roller to put it on(what size roller works best?). And then use a drywall knife to level everything.
I'm thinking about spraying a knockdown texture in there. So my questions are 1)I need to prime before texturing right? 2)Do I need to use any special primer for bathrooms? 3)After I texture I need to prime again right? 4)Then what kind of paint should I use for the top coat and can I roll the primer and paint over the texture?
Sorry for so many questions but just trying to make sure I get this right. Thanks for your advice.
ponch37300 is offline   Reply With Quote
Old 02-02-2009, 03:01 PM   #2
Do I need a mildew resistant primer or just mildew resistant paint? Thanks
Old 02-02-2009, 05:30 PM   #3
1) Yes, prime before texture.
2) No, no special primer. Any bonding/sealing water-base primer that is not Kilz2 should work.
3) Yes.
4) Topcoat with K&B paint. Both the primer and paint can be rolled.
sirwired is offline   Reply With Quote
Old 02-02-2009, 09:30 PM   #4
Thanks Sirwired, what kind of roller should I use for going over texture?
Old 02-03-2009, 02:29 PM   #5
To go over sprayed texture, I would use at least a 3/4" roller.
SirWired
Old 02-03-2009, 09:05 PM   #6
Thanks eveyone. I'll see how it goes.
Old 02-04-2009, 06:28 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
If there is any paste residue whatsoever, use a specialty primer first (alkyd or Zinsser's Gardz or similar)
A regular acrylic/latex/waterbased will activate any paste and you'll have failure of one type or degree or another
If it's clean, any acrylic primer will do
Then texture/skim/repair (joint compound et. al.)
Then re-prime (at this point any quality acrylic will do)
And yes, I'd suggest a self-priming bath-type paint
slickshift is offline   Reply With Quote
Help! Painting Textured Wallpaper - Going Nuts! AbbyDabby Painting 6 12-13-2008 06:18 AM
Painting over wallpaper RussellF Painting 8 11-01-2006 02:42 PM
painting over wallpaper derose Painting 4 09-02-2006 03:56 PM
painting over wallpaper linda mcginness Painting 4 10-28-2005 11:56 PM
