Old 11-01-2009, 10:46 PM   #1
Question Painting after removing Wallpaper
I removed 3 layers of wallpaper in a 95 yr. old house's living and dining rooms. It also required extensive patching to the plaster. I want to use an oil based primer to seal the patches, and Gardz to seal the wallpaper adhesive. My question is do I need both? If so, what sequence should I use to apply them?
fozzie is offline   Reply With Quote
Old 11-02-2009, 06:06 AM   #2
paper hanger, painter
chrisn's Avatar
Send a message via Yahoo to chrisn
No, one or the other will work, no need for both
Old 11-03-2009, 10:16 AM   #3
did you wash the glue off?
drewhart is offline   Reply With Quote
Old 11-03-2009, 05:50 PM   #4
Default Painting after removing wallpaper
I removed as much as the paste as I could, but I want to proceed on the assumption that there is still glue some I missed.
Old 11-03-2009, 07:59 PM   #5
chrisn's Avatar
There will always be some you missed( well almost always) but you should really try to get as much off as possible before using either Gardz or oil primer, not both.
More On This Topic
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
painting and wallpaper residue jayoshi Painting 1 09-13-2009 07:03 PM
Removing Wallpaper fcamargo6thave Painting 17 04-27-2009 04:59 AM
OOOLD wallpaper and painting Tab1975 Painting 7 04-07-2009 07:49 AM
Removing wallpaper and then painting applesusan Painting 7 02-24-2008 06:32 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
