-   -   Painting after removing Wallpaper (http://www.diychatroom.com/f4/painting-after-removing-wallpaper-56422/)
fozzie 11-01-2009 08:46 PM
I removed 3 layers of wallpaper in a 95 yr. old house's living and dining rooms. It also required extensive patching to the plaster. I want to use an oil based primer to seal the patches, and Gardz to seal the wallpaper adhesive. My question is do I need both? If so, what sequence should I use to apply them?
Thanks:confused1:
chrisn 11-02-2009 04:06 AM
No, one or the other will work, no need for both:no:
drewhart 11-03-2009 08:16 AM
did you wash the glue off?
fozzie 11-03-2009 03:50 PM
Painting after removing wallpaper
I removed as much as the paste as I could, but I want to proceed on the assumption that there is still glue some I missed.
chrisn 11-03-2009 05:59 PM
There will always be some you missed( well almost always) but you should really try to get as much off as possible before using either Gardz or oil primer, not both.
