Painting - Painting - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 01:24 PM   #1
painting
I'm painting a bedroom, but do I need to apply a second coat of paint?
m.g0mez is offline   Reply With Quote
Old 01-07-2010, 02:31 PM   #2
WindowTreatment Installer
It depends, did you put your first coat on yet ? If not and the room hasn't been painted in a while then I would prime first. The reason is your wall are probally real dry. Without priming the paint will just keep soaking into the walls and you will need several coats at least to cover. By priming first you will seal the wall preventing the paint from soaking in and provide a good surface for the paint to bond to. If you already applied your first coat without pimer, then appliy a second if it looks ok fine if not apply a third.
bobtheblindguy is offline   Reply With Quote
Old 01-07-2010, 05:40 PM   #3
Remodeling Contractor
you should always apply at least two top coats. And as posted in many cases a primer is also a good idea. For baths use Zinsser's PermaWhite to prevent mold and mildew. You can have this tinted to any color you want. Use it for both coats, since it is also used as a primer.
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 04:19 PM
