Painting - Painting - DIY Chatroom Home Improvement Forum
Old 07-08-2009, 11:48 AM   #1
painting
I:m using valspare outside paint like the way it covers , but i have a problem with it drying to fast. IN just a few seconds icant go back over it without it draging and leavin brush marks. Has anyone used this paint,and what can i do to correct this? The paint is real thick but it says not to thin unless using a spray gun. THANKS
upfront is offline   Reply With Quote
Old 07-08-2009, 04:04 PM   #2
Rewards Points: 16
You could add some Floetrol to help, but the real problem is that you're likely working in the sun, wind, when it's too hot, or your technique could be improved. Go with some Floetrol and try to paint under ideal conditions, if possible.
cej22 is offline   Reply With Quote
Old 07-09-2009, 03:45 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Go to a paint store and get some REAL paint
Old 07-09-2009, 08:18 AM   #4
Rewards Points: 16
While there are better products available, the paint is likely not the issue, and the OP would probably have the same problem even with Duration or Aura.
Old 07-12-2009, 02:01 PM   #5
Where do you get your paint wallmart. The paint is not the problem. I just wanted to know if the weather humity or smothing elsewas the problem.
Old 07-12-2009, 06:05 PM   #6
chrisn's Avatar
Rewards Points: 394
Maybe not, but you are going to have to supply many more details if you expect an answer. What was the weather,humidity,direct sun, wind, shade,cheap brush,etc,etc.
By the way Valspare( Lowes) is not considered QUALITY paint by any professional painting standards, neither is anything from Wallmart or Home Depot for that matter
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
