Painting 2 X 4 Studs - Painting - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 09:12 AM   #1
Rewards Points: 49
Painting 2 x 4 studs
I my "mechianical room" (furnace, water heater and laundry), I wanted to remove the drywall and paint the 2x4's and the inside surface of the drywall on the far side of the studs.
Do you see any issue with painting the 2 x 4's?
If not what paint/primer should i use?
thx allot!
john_bry is offline   Reply With Quote
Old 11-28-2012, 09:57 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
They're just wood, should be no problem. Depending how far you want to take them, prime and 2 coat everything.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-28-2012, 12:26 PM   #3
Rewards Points: 13,300
What your suggesting may be againt code.
Reason being most areas require fire code 5/8 sheetrock in a furnis room.
Old 11-28-2012, 01:58 PM   #4
Too Short? Cut it Again!
Should use a sealing primer, or a sealer first if they are pine or fir studs. Shellac any knotholes so they do not bleed through at the very least. You will need to paint the drywall before you paint it too.
Joe raises a good point about the fire code. On the living side of the furnace room you most certainly need 5/8. Perhaps not where you are on the side to the basement or whatever. Check code to be certain.
Mold remediation = replacing a few studs Jordan_Bailey84 Building & Construction 2 08-08-2011 09:21 PM
Mold remediation = replacing a few studs Jordan_Bailey84 General DIY Discussions 0 08-08-2011 12:00 PM
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-11-2006 12:10 AM
