Painting 150 Year Old Wood Trim -what Primer? - Painting - DIY Chatroom Home Improvement Forum
Old 07-24-2013, 09:32 AM   #1
Painting 150 year old wood trim -what primer?
Hi, I live in an old victorian with beautiful natural stained wood trim in the majority of the rooms.
I know a lot of people are against painting old stained trim, but we are only going to do it in one of the rooms where out dogs scratched and chewed the trim when they were puppies. The rest of the rooms we are keeping the wood.
Anyway, the trim is all orangy wood, might be fir or heart of pine, and I think right now it has clear poly acrylic on it. I have no idea what was on it before. I don't see any alligatory shellac and I did that rubbing alcohol test and it came up negative.
Anyway, what primer should we use? As I said, it's stained with I think poly over it (there are cans of clear poly in the basement from the last owners). Also, there are a few bare areas where my husband got over zealous with the sander.
I did try painting in one of the rooms before and used Smart Prime, but it was really thin and didn't go on well and I had to do two coats. Even tho I had sanded, it like kinda beaded up a little.
The people who lived here before used California prime choice 100% arcylic primer on some trim in the bathroom, but there are some knots bleeding thru now.
There are SO many kinds of primer out there, does anyone have a specific product that I should use?
If at all possible, I'd love some thing that doesn't smell too bad.
Last edited by Truest; 07-24-2013 at 10:01 AM. Reason: Wrong primer listed. Prime choice not fresh start.
Truest is offline   Reply With Quote
Old 07-24-2013, 10:26 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Prep is everything going over a clear coat. Lightly but thoroughly sand first ( 120 grit is about right) to give the primer a better chance to grip-
Primers that you want are bonding primers. Many good choices, 2 I like are Zinnser 123, Insul-x Stix, and I do also like Smart prime.
Primers are not meant to give great coverage- so no need for 2 coats. Thats what the finish paint does.
And use a quality paint meant for trim-
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
Gymschu (07-25-2013), Truest (07-24-2013)
Old 07-24-2013, 11:31 AM   #3
Jmayspaint's Avatar
Rewards Points: 534
If you can handle using an oil primer, the Zinsser odorless isn't too bad smell wise.
Its not quite as good as the regular Zinsser oil, but it might have a better chance of blocking knot/tannin bleed over time, than an acrylic.
http://m.homedepot.com/p/Zinsser-Bul...3296/202454927
Ben Moore sells a odorless oil also.
http://www.coronadopaint.com/downloa...20Odorless.pdf
123 is good stuff too (WB), and the 123+ is even better for stain blocking.. If you can get it. Seems to have diapered from store shelves lately..
Jmayspaint is online now   Reply With Quote
Old 07-24-2013, 12:01 PM   #4
BTW Jmay- 123Plus is the same thing as Smart Prime, just labeled for the box stores.
The Following User Says Thank You to Brushjockey For This Useful Post:
Jmayspaint (07-24-2013)
Old 07-25-2013, 01:00 AM   #5
Too Short? Cut it Again!
OP, what do you mean you do not like the way the primer you are trying is beading up? This makes me very nervous and suggests you are getting some chemical reaction between what you are putting on and the surface you have. This cannot end well. I promise.
This post confused me. Are we helping you paint over woodwork in one room where puppies chewed up antique trim or are we fixing new painted wood with knots bleeding through too? And the woodwork where a husband over zealous with a sander spent some time? All this happened in one room?
Typical Victorians often had expensive hardwood for public rooms downstairs and cheaper trim, and floors, made out of pine and fir upstairs. I do not cry too much when I see upstairs trim nicely primed and painted. I cringe seeing hardwood painted over though and was usually asked how best to get paint off of it.
Are you absolutely, positively sure you want to paint old Victorian hardwood, or even stained and clear finished upstairs soft wood though? If the dogs are done with their puppy chewing phase? Just replace what they destroyed. Or fix it. Don't paint the wood. You will be sorry if you start messing around painting nice exposed wood in a Victorian. I promise you, you will devalue the house near instantly too if you do. But if you must...
As mentioned Zinsser 123 know comes as a plus formula with stain blocker in a waterbased formula. I have no experience with it. Cover stain is the alkyd product from Zinsser and it has stain blocking properties. BIN is the alcohol or shellac based primer we talk a lot about. They stink in ascending order I guess and starting with Cover Stain you will need solvents for your tools.
Op if you have knots bleeding through layers of clear coat and then finish on it? Some piece of pine (or other soft conifer wood) did not get sealed before it was primed and then painted. $.30 worth of shellac would have helped. You cannot fix the situation from the top down now as the staining will seep out into whatever on top of it. You will have to strip the finish on that wood or remove and replace it.
Old 07-25-2013, 01:23 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
he's back
The Following User Says Thank You to chrisn For This Useful Post:
Old 07-25-2013, 01:44 AM   #7
Originally Posted by chrisn View Post
he's back
Don't get your hopes too far up lad!
Old 07-25-2013, 07:37 AM   #8
Hey SDS!! SUP?
And whats with this..??
Put a spot of BIN on the bleed and recoat- problem solved.
Old 07-25-2013, 08:41 AM   #9
Rewards Points: 6,034
WhY not look into a real repair? It really sounds like paint is not going to cover up the damage only make it more visible by making it different from every other room. A lot of the appeal of the old victorians is the beautiful woodwork. I think a half arse approach such as stain and poly would be better than paint.
Old 07-25-2013, 02:26 PM   #10
firehawkmph's Avatar
Rewards Points: 1,922
Can you post some pictures of the damaged woodwork?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-26-2013, 10:59 AM   #11
Originally Posted by Brushjockey View Post
Hey SDS!! SUP?
BJ, I have never had luck with this approach once unsealed resins have started seeping into the primer and finish. I know it should work but in most cases for me the stain just spreads under the sealer to the end of where I spotted the stain. This has been especially true when rather new, non-kiln dried pine or fir got milled and then installed too soon for trim. I found I could not fix the staining from the top down unless I took BIN or shellac to the whole piece of trim.
It was usually cheaper labor wise to just pull the trim, replace it, seal it, prime it and paint it as should have happened in the first place.
Old 07-26-2013, 12:17 PM   #12
Interesting. I don't think it's ever failed me.
Old 07-26-2013, 05:00 PM   #13
chrisn's Avatar
Rewards Points: 614
me either
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Painting over stained wood baseboard & trim Leenders Painting 6 02-23-2011 08:50 AM
Help selecting wood to trim out interior windows and doorways RobertN Carpentry 11 01-07-2011 04:38 PM
Tile with a wood trim? trick29392 Flooring 3 06-26-2008 07:19 AM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 04:32 PM
