Painting - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 12:40 PM   #1
Painting
I painted over a semi gloss walls in my bathroom. (Which I have done before without any problems) The paint is still tacky to the touch after 5 days and will literally peel off on some walls. How am I supposed to remove the paint?
Jewelslblack is offline   Reply With Quote
Old 01-17-2012, 03:34 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
Huh???
Old 01-17-2012, 04:38 PM   #3
Mr. Paint's Avatar
You have not indicated whatt ytpe of paint you used. Newer paints (Such as zero-VOC and some oils) are formulated with little solvent or high-solids alkyds which, promote slow dry. The answer may be more ventilation and more patience...
Mr. Paint is offline   Reply With Quote
Old 01-17-2012, 04:43 PM   #4
Rewards Points: 13,748
Is this room heated?
Old 01-26-2012, 01:24 PM   #5
What type of paint did you use over the semigloss?
The temperature or moisture may be the problem. Were the walls clean?
If you find that the temperature or moisture is the problem and allow the paint to cure by fixing the problem, then you can scrape off the bubbles and peeling paint. Then patch the spots with compound. Sand it smooth, prime the spots, then spot paint them. You might want to go over the walls again after the spots are done.
BeeTee is offline   Reply With Quote
Old 01-26-2012, 02:59 PM   #6
ARC Painting's Avatar
Is the bathroom constantly humid from shower and bath usage?
how clean were the walls?
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
New Member: Painting Contractor Induspray Introductions 3 01-04-2010 07:50 PM
Noob Painting Questions mark! Painting 6 12-09-2009 04:15 AM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
