Painting - Painting - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 09:19 AM   #1
Talking
painting
I have a concrete block wall. I have painted it with Loxon XP water repellent. It needs another coat of paint. Loxon is very expensive. what can i use over it to thoroughly cover the blocks. surely there is a cheaper water repellent on the market.
denney123 is offline   Reply With Quote
Old 11-13-2011, 04:13 PM   #2
Denney, I feel your pain. However, I don't think you'll find a comparable product for much less, a couple bucks at the most. If you go too cheap, that's what you'll get. You obviously have a concern about moisture if you're using it versus standard paint. Personally, I would appreciate the peace of mind I'd get for the extra bucks. You're only doing it once. Beside, it's possible you could have compatibility issues with another product. Not being a chemist, I can't say for sure if the first and second coat of Loxon XP don't depend on each other specifically, chemically, to form a waterproof coating. Just hand the guy your wallet, ask for it back when he's done, and look the other way. That's what I do.
Joe
Old 11-16-2011, 07:19 AM   #3
Question
help
what color paint do I use to paint over ugly orange on my wall? : / It does not work .... ;/
Ethan66z is offline   Reply With Quote
Old 11-16-2011, 07:24 AM   #4
Rubbin walls since'79
Brushjockey's Avatar
what color do you want? use that
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-16-2011, 09:32 AM   #5
jschaben
Rewards Points: 502
camo?
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 11-16-2011, 08:47 PM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
If you have a solid coat of Loxon on the block than you can use any latex on top of that. If you need more Loxon to cover some light spots or to jut even it out than you can thin the Loxon down some with water. That will actually help it flow into the holes better.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 04:19 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
