Painting - Painting - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 02:23 PM   #1
Painting
We have some newly installed Hardi Plank lap siding with rough cut grain pattern. I would like to know the brand of stain or paint to use on this material to make it look like cedar siding with a natural cedar finish / color.
I have seen it on a house on the Oregon coats and it looks totally awesome and holds up very well to this tough salt air inviroment with out the need to be repainted or stained evey year. Thanks Roger
Roger Brockway is offline   Reply With Quote
Old 08-17-2011, 07:39 PM   #2
Gymschu's Avatar
Rewards Points: 218
I have never STAINED Hardi-Plank, but, I have painted it. It holds up like nobody's business. A lot of painters feel the factory primer is a bit suspect with this product and they usually re-prime it with a masonry primer. Then, 2 coats of finish and you're done for at least 8-10 years. I have some HP on my garage that's going on 6 years and looks as good as the day it was put on. As for stain, I would do some research. I would suspect a solid color latex stain would work just fine, but, since stain is designed to soak into wood, it may not be as effective on HP. If it works, you could buy solid stain in a cedar color and stain away.
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 05:19 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
Painting over a sponge painted wall Snowdog Painting 3 03-17-2008 12:13 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
