Painting - Painting - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 09:27 PM   #1
painting
I put latex primer on my walls,then I found out that the paint that was on the wall was semi-gloss enamel. what can I do?
kittymo is offline   Reply With Quote
Old 06-15-2011, 10:33 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Put what ever you wanted to on for a finish coat and call 'er a day...
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
DangerMouse (06-16-2011)
Old 06-16-2011, 06:46 AM   #3
Too Short? Cut it Again!
As long as you deglossed the semi with sandpaper or a chemical deglosser you will be fine. You will probably be alright even if you did not and you used a high bond primer. You cannot put oil finishes over latex primers though.
Old 06-16-2011, 07:18 AM   #4
Don't worry about it.
??? Really?
painting exterior door JP79ST Painting 18 05-18-2010 04:04 AM
painting my mom house supaflyz Painting 5 07-28-2009 02:34 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 04:19 PM
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
