Painters Tape: Can I Leave It For A Bit Before Painting - Painting - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 02:08 PM   #1
Painters Tape: Can I leave it for a bit before painting
Hello, hope ur weekend's been good.
So Ive taped the whole room up laboriously around the megaton of molding and 7 foot windows. By the time we were done was too late for painting. Will return in 3 days to edge and roll with primer.
Is a few days much too long to leave scotch blue on the trim? (no paint applied yet). I know its not ideal, but wondering if its a huge problem.
thanks folks!
trupro is offline   Reply With Quote
Old 01-30-2011, 06:18 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 140
It will be fine
Old 01-30-2011, 09:35 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 852
Originally Posted by chrisn View Post
It will be fine
I'd say 50/50 without knowing the whole story.
-Paul
Sir MixAlot is offline   Reply With Quote
Old 01-31-2011, 01:15 AM   #4
chrisn's Avatar
Rewards Points: 140
-Paul
Well, I will not argue that!
Old 01-31-2011, 01:31 AM   #5
Registered User
Rewards Points: 4,924
14 days; http://www.lowes.com/pd_43066-98-209...%2Bblue%2Btape
7 days and 1/2 as wide; http://www.lowes.com/pd_42582-98-209...%2Bblue%2Btape
Gary
Old 01-31-2011, 11:16 AM   #6
Faron79's Avatar
Rewards Points: 260
As a torture-test...
3 yrs. ago, I did some Poly-ing on our laundry-room window trim downstairs. I had taped-off the inner wood trim from the outer casing.
PURPOSELY left tape on 3 MONTHS...ALL SUMMER. Window got some late-aft. sun every day.
Came off perfect...NO residue/lifting of existing Poly, which had been on for a few months. I had pressed tape down firmly too, across the whole width of 2" tape. This was the REGULAR 3M Blue, not the delicate-surface.
Faron
Faron79 is offline   Reply With Quote
Old 01-31-2011, 02:06 PM   #7
iminaquagmire's Avatar
Rewards Points: 338
It really depends on the surface its applied to and how well whatever its applied to is adhered to whatever is underneath that. I've seen it pull off huge sections of paint. A little heat with a hairdyer will help loosen it a little and a LIGHT pass with a sharp utility knife in corners can help in stubborn spots. Remember to pull at a 45 degree angle at a moderate speed without any jerking motions.
Personally I think cutting with a brush produces better results if you can do it. Its worth the practice to get it right.
iminaquagmire is offline   Reply With Quote
Old 02-01-2011, 10:51 AM   #8
Rewards Points: 394
If you end up painting, and overlap the tape, either remove the tape when the paint is wet, or use a razor knife to score the edge of the tape to prevent lifting the paint.
Will22 is offline   Reply With Quote
Old 02-02-2011, 01:53 AM   #9
Super Master Painter
Ole34's Avatar
It will be fine
i agree with this guy...........but just dont leave it for to long or it will fall off by itself
Ole34 is offline   Reply With Quote
Old 02-02-2011, 06:11 PM   #10
Professional Painter
Just blogged about this....
mattroefer is offline   Reply With Quote
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 04:45 PM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 10:27 PM
Help-Paint peeling with blue painters tape tammymitchell Painting 6 09-04-2008 07:18 PM
Blue masking tape: How long to leave on? digexpressions Painting 4 08-14-2008 05:56 PM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
