Painters Tape? - Painting - DIY Chatroom Home Improvement Forum
Old 02-06-2014, 06:48 PM   #1
Painters tape?
I bought the blue painters masking tape from lowes to mask off the floor when painting my cabinets. This stuff was horrible. When it came time to tear it off the floor, it tore in pieces and there were spots the paint got onto the floor, im guessing it bled through the tape..? Whats a good masking tape to use?
mopower440 is offline   Reply With Quote
Old 02-07-2014, 04:19 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 128
Did you buy "their" version or 3m
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (02-07-2014)
Old 02-07-2014, 07:44 AM   #3
Gymschu's Avatar
Rewards Points: 230
I don't use a lot of masking tape, but, when I do, I use FrogTape.
The Following User Says Thank You to Gymschu For This Useful Post:
princelake (02-07-2014)
Old 02-07-2014, 07:50 AM   #4
Rewards Points: 12,856
Did you wait until the paint dried before removing? Do it when it's still wet and it comes right off.
Did you fold it back on it's self and slowly pull it at a slight angle?
Old 02-07-2014, 07:54 AM   #5
Jmayspaint's Avatar
Rewards Points: 534
Frog tape is better, or the 3M with edge block.
But whatever tape you use, whether paint bleeds through the edge or not has a lot to do with how you put the tape on. It helps to push the leading edge down firmly with a putty knife.
Jmayspaint is online now   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Gymschu (02-07-2014), VAProPainter (02-07-2014)
Old 02-07-2014, 09:22 AM   #6
Rewards Points: 5,974
Lowe's now has it's own brand Blue Hawk and everything is blue. So my question is the same as Chris. I used to use the 3M blue tape in my hand masker, it didn't take long for this to get retry expensive. Now unless I'm going to leave it on I just use regular 3M 2020 masking tape.
Old 02-07-2014, 05:34 PM   #7
chrisn's Avatar
Rewards Points: 128
me too
The Following 2 Users Say Thank You to chrisn For This Useful Post:
kkeith (02-08-2014), ToolSeeker (02-07-2014)
Old 02-07-2014, 11:24 PM   #8
Rewards Points: 512
ya i dont use tape often but when i use frog tape to. i paint almost daily and a roll will last me about a year. i only use it for some real goofy corner/ angle. or when theres 2 door casing in a corner 1/2" apart and i cant get a brush in there nicely.
princelake is offline   Reply With Quote
Replacing tape joint on stippled ceiling Rusty Skillz Drywall & Plaster 4 11-01-2012 09:41 PM
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-22-2010 12:13 AM
Aged Painting Tape Needs to Come Off user1007 Painting 2 03-04-2010 06:16 PM
peeled primer (left the blue tape on too long) tjmack Painting 2 02-25-2010 01:16 PM
Painter's Tape Unregistered Painting 1 06-06-2004 12:31 PM
