Painters Caulk Vs. Something Else? - Painting - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 02:58 PM   #1
Painters Caulk vs. Something Else?
I have about 8 tubes of white DAP Painters Caulk from a different project. Works great for baseboard, trim, etc.
I am starting another project and wondering if this is the right stuff. I have to prepare 6 large, north-facing windows for white trim paint. I am filling in the tiny cracks between pieces of trim. Between casing and wall. Between casing and jam. Between jam and replacement window plastic, etc.
Can I use this? Or should I use a paintable caulk that is more specific to weathersealing?
FirstAndTen is offline   Reply With Quote
Old 02-11-2011, 09:29 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I would because Dap is very prone to crack. Sherwin Williams and AllPro make good Caulk.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
FirstAndTen (02-14-2011)
Old 02-12-2011, 11:27 AM   #3
Rewards Points: 252
if it was the dap alex plus with some silicone in it, then it's ok - not the best out there but it does flex and hold up ok (not as good as the SW stuff). If it's their regular painters caulk - than yes, it is definitely prone to crack - I don't even like using that stuff for interior caulking.
mazzonetv is offline   Reply With Quote
The Following User Says Thank You to mazzonetv For This Useful Post:
Old 02-12-2011, 07:34 PM   #4
iminaquagmire's Avatar
Rewards Points: 338
GE Silicone XST. Its paintable within 30 minutes and 100% silicone so it won't crack.
iminaquagmire is offline   Reply With Quote
The Following User Says Thank You to iminaquagmire For This Useful Post:
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 04:36 PM
Best caulk for metal windows and brick walls Ginette General DIY Discussions 5 09-08-2010 05:29 PM
Best Bathroom Caulk for 2010? SimpleJack Plumbing 9 04-01-2010 04:12 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 07:03 AM
recaulking: cleaning out old caulk questions adamc Painting 6 09-19-2008 05:30 PM
