Painted Sheetrock? - Painting - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 09:21 PM   #1
Painted sheetrock?
My wife and I just bought a home that was built in 1959. Needless to say, lots of wallpaper everywhere. I started taking the wallpaper down in the master bedroom and it appears as though it was wallpapered over what seems to be a wallboard w/ a pattern on it. Anyone know what this is? HOw should I deal with it? We want to just paint the walls, but as I try and remove this, it seems to be almost like sawdust underneath it. I'm worried it could be asbestos (mostly because I've heard that's bad/expensive and that tends to be my luck).
bleuvenom is offline   Reply With Quote
Old 10-24-2008, 04:13 PM   #2
Drywall contractor
Rewards Points: 1,070
I don't have a clue what you have.........can you post some pictures?? Never seen wallboard with a "pattern". There is a product available with vinyl wallpaper already on it and it COULD have a pattern. I highly doubt it was available in '59 and it is installed with a filler strip between sheets rather than a smooth transition between the pieces............
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-24-2008, 08:13 PM   #3
Workaholic's Avatar
I too do not know hat you are dealing with and second a pic. Is there any chance the pattern you are seeing is sumthing that bled through from a previous paper?
Sean
Workaholic is offline   Reply With Quote
Old 10-25-2008, 05:13 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
This happens all the time, it was the sawdust thing that was really confusing.
Old 10-25-2008, 08:42 AM   #5
Drywall contractor
Unless the backing paper and glue are deteriorating and leaving residue that looks like sawdust??
Old 10-25-2008, 11:26 AM   #6
Eibwen
I remember rehab'ing a house in DC back in the 1970's...
Somebody had redone the walls and used the boards off of one of those big war table maps you see in the movies they push ships and tanks around on with sticks.
Any tanks in the design?
Sammy is offline   Reply With Quote
Old 10-26-2008, 03:59 PM   #7
Drywall contractor
Now that's a FIRST!
Old 10-26-2008, 09:23 PM   #8
Eibwen
Yeah the house was only about six miles from Fort Fumble [ Ya'll probably call it the Pentagon] and I'm sure somebody scavenged the boards and used em to finish off a wall on a small additition.
Old 10-27-2008, 09:59 AM   #9
Drywall contractor
Our tax dollars being recycled.........
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 12:50 PM
Sheetrock mudding over existing painted textured surface? SKINNY Remodeling 8 10-13-2008 01:00 PM
Lay sheetrock over fireplace with wood burning insert??? amycarlson Building & Construction 13 06-13-2008 09:00 AM
Sheetrock question Vengence Remodeling 4 07-13-2007 11:42 AM
