Painted Over Glitter - Painting - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 12:21 PM   #1
Rewards Points: 14
Painted over glitter
Hi. In a bedroom of the home I recently bought, there is glitter on the walls. It looks as though the walls were pink, and the glitter was sort of thrown onto the walls. Before selling, the homeowner painted the walls white, without trying to remove any of the glitter. As a result, the glitter is very difficult to remove. I've tried sanding (by hand) and scraping, but neither is very effective.
Would a power sander or some other method be better? I'm attaching a picture, not sure if it will help.
Thanks!
Dave43026 is offline   Reply With Quote
Old 10-22-2011, 12:44 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
It's hard to see from a small pic- is the paint separating off the glitter?
Is it sticking out and rough?
When you sanded- did you use a course paper or screen on a handsander with a handle? ( 80 grit+ more flat pressure than a hand held piece or a sponge)
It might require a skim with taping compound, sand prime, finish.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-22-2011, 01:03 PM   #3
Rewards Points: 14
The paint is not separating off the glitter - just sticks out through the paint, making it the wall look bumpy. When you run a piece of course sandpaper over it, it takes the paint off the glitter so that it's exposed again. I've only tried the course sandpaper, and you really have to work at it to get the glitter off. It's a larger room, so just wondering if there's an easier way.
Old 10-22-2011, 01:11 PM   #4
Rewards Points: 526
I would be tempted to try an orbital sander with 100 grit paper. If it failed to remove the glitter, at least it would grind down the edges and make the wall flat.
Windows is offline   Reply With Quote
Old 10-22-2011, 05:06 PM   #5
I would take a thin blade, flexible spackle knife and try to "chip" it off. Come at it from the side with the blade almost as perpendicular to the ceiling as you can get, and just try to chip away at it. Give it some time and play around with it trying different approaches. It may work. I use my blade prior to sanding really rough walls and it takes a lot of stuff off that I would otherwise have to sand. (My blade has a razor edge from all the wall scraping it's used for though, at least if slices skin like a razor lol, and it does slice paper) Before you get involved in skim coating an entire ceiling, or creating a major dust storm, you need to be willing to try everything.
The Following User Says Thank You to jsheridan For This Useful Post:
ltd (10-22-2011)
Glitter on Ceilings dawndweezie General DIY Discussions 3 03-02-2011 07:00 PM
All surfaces painted with a brush different from surfaces painted with a roller. praktikal Painting 16 04-06-2010 09:45 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 12:50 PM
recapturing door frame pen and pencil growth chart height marks that were painted ove jsbujtor Off Topic 0 09-27-2009 06:08 PM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 12:50 PM
