Painted Kitchen Cabinets (They're Sticking) - Painting - DIY Chatroom Home Improvement Forum
Old 04-08-2014, 06:34 PM   #1
I sanded, primed with Zinsser, and painted with Bear semi-gloss. Doors are hung and adjusted and all is beautiful; except some of the cabinet doors are sticking. To the silicone seal in side the kitchen cabinet. I've used alcohol to wipe off excess paint and stop sticking. However, a couple are still doing it. What solvent can I use that won't give me a bigger "gummier" mess?
sweetnyx is offline   Reply With Quote
Old 04-08-2014, 06:50 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
Is it oil or water base paint?
Jmayspaint is online now   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
sweetnyx (04-08-2014)
Old 04-08-2014, 07:02 PM   #3
Water based paint
Old 04-08-2014, 07:25 PM   #4
water based paint
Old 04-09-2014, 11:57 AM   #5
Rewards Points: 394
This is called "blocking", as latex paints do not form a hard film. Alcohol will soften the paint. Use talcum powder to alleviate sticking.
Will22 is offline   Reply With Quote
The Following 2 Users Say Thank You to Will22 For This Useful Post:
gregzoll (04-13-2014), sweetnyx (04-09-2014)
Old 04-09-2014, 12:48 PM   #6
Rewards Points: 256
If the door is sticking to the frame then get those little silicon half circle door stops or self sticking felt on corners.
JustinK is offline   Reply With Quote
The Following User Says Thank You to JustinK For This Useful Post:
Old 04-09-2014, 01:05 PM   #7
I was wondering if that would work. Thank you Will!
Old 04-09-2014, 01:09 PM   #8
Thanks JustinK! That idea may help me with a different cabinet problem I'm having!
Old 04-11-2014, 05:39 AM   #9
The old finish has to be completely stripped off or the paint not stick. Its a very tough job but can be done. i also was paint in the kitchen reaper white i do not have idea but after lot of struggle i select the code and do it...
darren222 is offline   Reply With Quote
Old 04-13-2014, 01:14 PM   #10
Gymschu's Avatar
Rewards Points: 184
Uh, Darren, I doubt she wants to strip off the NEW finish she just applied. Wow!!!
Old 04-13-2014, 03:13 PM   #11
Rewards Points: 6,652
Sometimes you have to, to do it right. Behr is one paint that I will never let enter my home. I use mainly Valspar in my home. Never had any issues with it.
Old 04-13-2014, 03:15 PM   #12
What is the humidity level in the home? How hot was it where you painted the cabinets? Did you paint them in the Kitchen, or take the doors out to the garage and paint them?
Depending on the temp & humidity inside the home. Plus the fact that you used Behr paint which is half the problem. The other question is how long ago did you paint the cabinets? Also was the paint stirred very well? What was used to clean off the surfaces of the cabinets and doors, before you painted them?
Old 04-13-2014, 03:28 PM   #13
There's a box. A door. Attached by a hinge. With a handle. Maybe a bumper rubber or felt. What is this "silicone seal" we are talking about?
Pic?
Danahy is offline   Reply With Quote
Tags
cabinets , paint , silicone seal , sticking
What color to paint kitchen cabinets? kimberland30 Interior Decorating 20 11-28-2015 04:33 PM
Refinishing/painting kitchen cabinets Cobrakillert Painting 4 03-05-2011 03:15 PM
Replace kitchen tile without moving cabinets and countertop stubits Tiling, ceramics, marble 7 02-18-2010 11:56 AM
diy built-in kitchen cabinets Jeremy Hillary Boob, PhD Carpentry 6 11-30-2008 12:46 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
