Painted Floor - Painting - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 12:52 PM   #1
Painted floor
We painted a bedroom floor with 4 coats of latex satin paint, then painted the first coat of water based polyurethane. Yellow stains are now appearing throughout the floor. Don't know what next step should be. Help!
bethschulberg is offline   Reply With Quote
Old 07-17-2010, 02:08 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Did you use a floor enamel? Sounds like you just used a wall paint on a floor, if so it won't last and four coats is a little excessive and not necessary. Did you use water or oil base poly? Depending on what kind of poly you used it will yellow the paint, hope you did not use oil base poly over latex paint as that will cause problems with the paint as well, a quality water base poly is clearer than an oil base poly and dosnt have that amber tint to it.
housepaintingny is offline   Reply With Quote
Old 07-17-2010, 06:01 PM   #3
painted floor
Thanks for your reply. Yes, we used latex wall paint and a water based poly.
Can't figure it out, so now have moved on and put down a coat of actual floor paint. Seems to be working well.
Old 07-18-2010, 03:31 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
Over top of what you already did?????
Tiling Over Painted Concrete Floor?? kiss44 Flooring 13 07-06-2011 04:41 PM
Darn Painted Concrete Floor TrJean Flooring 6 04-08-2010 12:44 PM
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 08:59 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
