Painted Deck - Advice Needed! - Painting - DIY Chatroom Home Improvement Forum
Old 03-22-2007, 11:16 AM   #1
Painted deck - advice needed!
Hello, all,
I have a pretty large deck 70' by 14' that was painted by the previous owners. At least I think it's painted, it's peeling up all over the place. I would have liked to sand it completely down and stain it a more natural color, but I've been advised that the paint would remain along the sides and in between the boards and it just wouldn't work very well. So I assume my best bet is to sand it and then repaint it. True? I tried using a hand held sander just to see what it would do and it didn't even make a dent in the paint that is still solid. Should I just get the high spots and then repaint? I've also tried using a paint stripper on it with pretty underwhelming results, though it did remove some of the paint. Tedious work, though.
Any advice as to how to proceed? Thanks in advance!
Sallie is offline   Reply With Quote
Old 03-22-2007, 12:05 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Stripping or sanding for re-staining would be a huge time and money consuming project...huge
Todays strippers are not nearly as effective, or toxic, as the older ones
But the waste is still hazardous and must be disposed of as per your local regs
It would be a very, very, messy, stinky, job
The best way would be to rent a giant floor sander
That would take time, and skill, also...they don't move too fast and can ruin the deck quickly...and all the nails must be pushed down below the surface....
And even when your done there's still tons to do by hand and small sanders
...it's still a huge project
I'd recommend re-"painting" with a solid color stain, looks like a paint or re-decking with new material and staining to the color you'd like
slickshift is offline   Reply With Quote
Old 03-22-2007, 01:31 PM   #3
Pro Painter
As far as stripper goes, forget about it. Even the strong methelyne chloride strippers don't work well in sunlight and open air. Even if it did, paint tends to remain in the grooves and cracks.
Powerwashing might do better for this job, whether repainting or staining.
Another option is to powerwash and seal the decking, then flip all the boards and start with fresh wood. But both options still leave spindles and handrails to deal with.
joewho is offline   Reply With Quote
Old 03-22-2007, 03:25 PM   #4
Thanks, Guys,
I have already powerwashed the deck a couple of times hoping to dislodge some of the peeling paint, and it took some of it off but there still needs to be some sanding or something done before I'd get a halfway even finish to work with. The paint that is not in the sunlight looks fine for painting over, it's the few feet that are in direct light that I'm going to have trouble with. Then, of course, as Joe said, that still leaves the spindles and rails. It looks like whatever I do, it's not going to be an easy job and certainly not something I'm going to want to tackle on my own. Unless I just slap a coat of paint/stain over it the way it is now which is actually starting to look better and better to me right now! What about outdoor carpet? Have either of you had any experience with that?
Thanks for your replies!
Old 03-22-2007, 03:30 PM   #5
Pro Painter
Paint work provides 2 things: Preservation and beautification. Although most of the focus is on appearance, the higher importance it preservation. LOL, paint it!
My only experience with outdoor carpet is removal. Right now there needs to be a coating that will save the wood. I don't think carpet is a good choice for that.
Old 03-22-2007, 11:03 PM   #6
OK. That sounds like the best thing to do. Guess I know what I'll be doing on my vacation this year!
Thanks for your help!
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Deck - 45 spindles - advice wanted (pics inside) Kevin K Building & Construction 21 06-06-2007 10:28 AM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 03:55 PM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 11:17 AM
