Old 02-27-2013, 01:45 PM   #1
Talking
painted concrete carport
My husband and I made the mistake of painting our concrete carport. We started off with red and when that started peeling off we went to concrete grey. We thought we did it right, but the paint will not stay on and now it has about six coats of paint on it. It is still peeling off. What can we do to take the paint off and get it back to the natural concrete?
ncarrier is offline   Reply With Quote
Old 02-27-2013, 02:01 PM   #2
What type of paint are you applying? If it is standard porch and floor paint, it will not take hot tire traffic. It would have to be removed with a chemical paint stripper.
Will22 is offline   Reply With Quote
Old 02-27-2013, 02:39 PM   #3
cdaniels's Avatar
You're going to have to strip it chemically or mechanically.You have to get down to the concrete and start over with something that will bond and hold up to tires like an epoxy coating made specifically for garage floors.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 02-27-2013, 02:43 PM   #4
Gymschu's Avatar
Need more info........what type of paint was used on the carport before? An oil, a latex porch and floor, etc. Are you talking about the block walls of the carport or the actual concrete floor? Concrete is funny stuff.
The Following User Says Thank You to Gymschu For This Useful Post:
cdaniels (02-27-2013)
Old 02-27-2013, 05:53 PM   #5
paper hanger and painter
chrisn's Avatar
sand blast
Old 02-27-2013, 08:20 PM   #6
I had a large "carpet" painted on my patio by a previous owner. Used a pressure washer and it readily removed it.
____________
Vince
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
trimming off painted basement concrete steps Jonesy56 Concrete, Stone & Masonry 1 06-18-2012 09:02 AM
Tiling Over Painted Concrete Floor?? kiss44 Flooring 13 07-06-2011 05:41 PM
Can you stain a painted concrete floor? linda nelson Flooring 1 07-05-2011 10:31 PM
Adding drain(s) to concrete floor in carport? mark2741 Building & Construction 8 04-19-2011 06:27 AM
