Painted Coffee Table - Painting - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 12:35 PM   #1
painted coffee table
my coffee table paint rubs off when I dust it or even just rub a dry rag over it. What can I put on it to keep this from happening.
patsylouhoo is offline   Reply With Quote
Old 03-25-2013, 12:45 PM   #2
Rewards Points: 12,882
Sure sounds like someone painted it without the proper prepping.
Anything you apply over it still would have nothing to keep it stuck on.
Old 03-25-2013, 02:27 PM   #3
Rewards Points: 394
If you painted it with a regular latex paint, it may be sticky, which is called blocking. Provided that it has very good adhesion, applying a waterborne clear varnish can help. Cleaning a painted surface is done with a cellulose sponge and water, no abrasives or ammoniated cleaners. Most manufacturers recommend allowing the paint to cure for 30 days before cleaning.
Will22 is offline   Reply With Quote
Old 03-25-2013, 04:19 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Rubs off as in a little color , or are chunks of paint peeling off?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Fix warped table top edge hovercarracer Carpentry 2 10-17-2012 05:37 PM
electrical johnx Electrical 29 06-22-2011 07:52 PM
Need help getting measurements of pieces I need to cut to build coffee table. JaronDaWizard Building & Construction 2 05-01-2011 10:27 PM
Building a coffee table, got a question aberrant Building & Construction 7 02-14-2011 01:02 AM
Help please with table support Stonefury Carpentry 2 01-07-2009 02:05 AM
