Painted Chipped/peeld Off - Painting - DIY Chatroom Home Improvement Forum
Old 12-25-2013, 02:52 PM   #1
Rewards Points: 878
Painted chipped/peeld off
We just had this painted recently and it chipped/peeled off when we took off the moulding. What is the best way to fix it? Does it have to be spackled? Thanks
Painted chipped/peeld off-image-267322848.jpg
Mstrlucky74 is offline   Reply With Quote
Old 12-25-2013, 06:14 PM   #2
Rewards Points: 4,796
Yes it should be spackled (any joint compound), spot primed, and painted. I don't bother with the spot prime for flat paint.
jeffnc is offline   Reply With Quote
Old 12-25-2013, 07:44 PM   #3
Rewards Points: 878
Thanks...it's a matte finish. When you say "spot prime" that means any primer and just go over the compound area with it? Thanks
Old 12-25-2013, 07:46 PM   #4
Yes. Well, not "any" primer. It should be a drywall sealer. For matte finish I would spot prime.
The Following User Says Thank You to jeffnc For This Useful Post:
Mstrlucky74 (12-25-2013)
Old 12-26-2013, 08:21 PM   #5
Rewards Points: 5,978
To keep this from happening again before you remove something like this run a sharp utility knife along the edge in case any paint has stuck to it.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Mstrlucky74 (12-26-2013)
Old 12-27-2013, 04:37 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 494
Originally Posted by audrycampbell View Post
The main cause of paint cheeping is bad surface preparation. if the surface is not clean and contain oil then these types of problems occurs. The solution of this problem is to cover the surface with a new surface.
Old 12-27-2013, 07:27 AM   #7
That sounded like one of those eHow pages, where you got slave labor in some foreign land cutting and pasting How-To information they Googled on the internets.
There's this gem about apparently adding more mold to your bathroom:
!st serious DIY Bathroom remodel- wish me luck!
And of course this classic:
Masonary paint
He probably should be banned, but I can't figure out what he's up to.
Old 12-27-2013, 07:31 AM   #8
[duplicate]
Painted floor LifeAtHome Painting 2 09-06-2013 03:14 PM
Seeking help and advice with hideous painted brick fireplace sparkler22 Painting 12 12-03-2011 06:46 PM
All surfaces painted with a brush different from surfaces painted with a roller. praktikal Painting 16 04-06-2010 08:45 PM
recapturing door frame pen and pencil growth chart height marks that were painted ove jsbujtor Off Topic 0 09-27-2009 05:08 PM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 11:50 AM
