Painted Bolts - Painting - DIY Chatroom Home Improvement Forum
Old 08-20-2008, 07:56 PM   #1
zcb
Painted bolts
I just moved into a house that has hurricane window covers. They are heavy vinyl and they attach to the bolts that are already in the outdoor wall around the windows. Problem is that the previous owner painted the bolts and now when I went to attach the covers using wing nuts, I could hardly get the wing nuts to turn on the painted bolts. Help...... this is hurricane season and we've already had one close call. I tried a wire brush and that helped some, I tried a rag soaked in paint remover but that didn't do a thing. Any suggestions will be greatly appreciated.
zcb is offline   Reply With Quote
Old 08-20-2008, 08:04 PM   #2
Try a heat gun with a heat shield behind it as to not damage anything else.
A wire wheel on a drill might help as well.
KHouse75 is offline   Reply With Quote
Old 08-21-2008, 01:08 AM   #3
Rewards Points: 2,906
ZCB:
Take one of the wing nuts to any place that sells fasteners and find out what kind of a thread it is. Buy a die for that size of screw thread.
Running that die onto your bolts will cut the paint off the threads.
I realize it can be easy to mistread the die if the bolt threads are all caked up with paint. So, maybe just thread the die on with your fingers until you're confident that it's threaded on correctly before turning the die with a wrench or socket.
Nestor_Kelebay is offline   Reply With Quote
Pipe Fence Painted NOW Flaking~HELP! jackieO Painting 2 06-01-2008 08:33 AM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 03:55 PM
Retexturing painted popcorn ceiling kwehnes Building & Construction 6 01-02-2007 04:36 AM
Anchor Bolts..what do you use scarrell Building & Construction 7 04-06-2006 10:03 AM
