Paint Wood To Minimize Warping? - Painting - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 01:31 PM   #1
Question
Paint wood to minimize warping?
This makes sense to my inexperienced mind but what kind of paint is best to minimize the warping of wood? Oil or latex? Or would polyurethane do a better job?
In this case it is kiln dried (white wood) 2 x 4's that I screwed together to form a basic square frame. Then I braced the corners and added a mid brace. I'll will be covering the frame with sheet rock on both sides. They will remain in the inside of the home. Any warpage of the frames would ruin the project. The bracing of the frames will help but the extra step of painting before I screw on the sheet rock would be well worth it. Just not sure what to paint with. Hopefully some of this leftover latex I have here will work just as well as anything else since I barely have a dime for any more materials. I would sure appreciate your input.
Thank you,
Dave
extradave is offline   Reply With Quote
Old 07-17-2011, 02:31 PM   #2
This is the biggest myth ever.
Any finish will slow but will not prevent or reduce warping.
Moisture will still find its way in.
I don't see a problem you said both sides will be covered with sheet rock.
As long as nears no water near or moisture.
StevenH is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
I can't paint my whole exterior before winter, and I have some exposed wood skiposwald Painting 1 10-15-2008 01:06 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
