Paint Wont' Stick - Painting - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 01:21 PM   #1
paint wont' stick
We have a very old farmhouse - we have redone most rooms. The wals are the old plaster - not horse hair - a bit newer - but cracks easily - we painted 2 years ago - Now one wall and window frame won't hold the paint. We primed it first with kilz the used good quality paint. Now it is all coming off. Primer and all. right down to the bare wall and wood. Could we have a fungus or mold in the wood or wall? What do I do to keep the paint on the wall. I don't see the mold or fungus but it is very old wood and plaster.
melonsforyou is offline   Reply With Quote
Old 01-31-2012, 03:17 PM   #2
BraniksPainting's Avatar
So, you are saying your plaster is newer? If so, there is your issue. How long did you wait before painting the newer plaster? Back in the day you would have had to wait a year before even touching paint to plaster due to the acididity (lime) in the plaster. Even now, with advanced paint and newer plaster compounds you need to wait at least one week. At that you would have to use a paint that is made specifically for masonary/plaster because the lime needs time to dry out.
I'm not certain why it would be peeling from the window frame. Possibly a water issue. We had bad ice storms here two years ago and outside my office window a huge icicle formed. When it melted all of my paint peeled from the window frames.....right down to the bare wood.
BraniksPainting is offline   Reply With Quote
Old 01-31-2012, 03:52 PM   #3
Look on the outside wall for any breaches that may be allowing moisture in from the outside. Is the house stone? Branik missed your point about the age of the plaster, just a bit newer--than horse-hair plaster!, lol, but he got the analysis correct. Generally, failure down to the substrate is moisture related. I'd venture to bet that you have a lot of moisture transfer outside to in. It could be from a single breach, like an uncaulked window frame or transferring through the wall, or both. How widespread, or limited, is it?
The Following User Says Thank You to jsheridan For This Useful Post:
Gymschu (02-01-2012)
Old 01-31-2012, 04:16 PM   #4
Mr. Paint's Avatar
When you have solved the moisture issue, prime the walls with Zinsser GARDZ primer. Unlike KILZ, this will penetrate and tie down anything that may be loose. Kilz is for killing stains. Rapid-Dry primers flash off quickly and will not penetrate a surface very well which, I think would be called for in your case.
Prime the wood with a high-quality enamel undercoater before painting.
Mr. Paint is offline   Reply With Quote
Old 01-31-2012, 09:24 PM   #5
Rewards Points: 388
Hi Melons,
I agree with Mr Paint, I don't think Kilz (water or oil based) was necessarily the best primer...especially for the plaster walls. My guess is that your plaster is very hard and slick, which is typical of old plaster. Before re-priming, etch the exposed plaster with a 50/50 mix of white vinegar and water to create a profile for better adhesion of the primer...be sure to rinse with clean water before priming. Zinsser's Gardz Sealer would work well on plaster and actually may strengthen any crumbling plaster.
You really didn't give much info about the wood, but if it's dry and a little gray, you're going to do better by priming with a slower drying oil based primer. I hope this helps, good luck.
ric knows paint is offline   Reply With Quote
PreVal Sprayer: Anybody Tried It With Latex? Twister Painting 7 10-17-2013 12:36 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Doors stick after recent paint n0c7 Painting 4 04-28-2010 03:54 AM
Painting a garage door dfoxworthy Painting 6 06-22-2008 10:51 PM
