Paint That Won't DRY!!!!!!!!!!! - Painting - DIY Chatroom Home Improvement Forum
Old 02-16-2008, 04:59 PM   #1
Question
Paint that won't DRY!!!!!!!!!!!
Hi
We are new members and are currently painting a room in our house. Wallpaper was stripped originally and the room has been filled and sanded due to hairline cracks. Before putting on the first coat we sealed the walls with diluted Super Evo Bond PVA
Anyway we have now put 1st coat on the walls and in some parts the paint is not drying, in fact it is still very wet, after 2 hours 90% of the room is dry. Mainly in one corner the wall is still wet. Any tips or help would be very much appreciated.
L&R W
LauraW is offline   Reply With Quote
Old 02-16-2008, 06:27 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
What is the wall made out of?
What was the PVA put over?
slickshift is offline   Reply With Quote
Old 02-17-2008, 05:27 AM   #3
wall is 30 year old plaster and when wallpaper taken off left a pale green covering on plaster - some sort of paint
Old 02-17-2008, 09:33 AM   #4
LauraW, If it's mold of some sort, the wall itself will always be damp. Back in NYC, we had plaster walls and it was not uncommon for this to happen. Plaster, drywall, wood are "food" for the mold.
End Grain is offline   Reply With Quote
Old 02-17-2008, 09:54 AM   #5
remodeling pro
Don't panic just because the paint is still wet in the corners, or any where else for that matter, in only two hours. This is even more so when painting over what is basically an impervious wall (The old primed plaster) , so the only drying that can happen is through evaporation on the open room side, nothing can soak into the wall. Two things you read on paint cans that should never be believed....DRY in 30 minutes, and one coat coverage.
troubleseeker is offline   Reply With Quote
Old 02-17-2008, 12:23 PM   #6
Great many thanks, we have used a dehumidifier in the room and this has dried out the walls thankfully
Old 02-17-2008, 05:11 PM   #7
slickshift's Avatar
...didn't see the "2 hours" part
That would be normal
Most paints should dry to the touch overnight
Old 02-24-2008, 12:50 PM   #8
She'sapainter
I'm sure now your problem has been solved but in the future the only time you need PVA sealer is for new sheet rock. you can sometimes use just a regular can of flat or eggshell paint how ever it does not adhear to patches as well. It really depends on what type of climate you live in when you paint and what kind of paint you use how thick you apply itr as well as times you should paint believe it or not. Moist and cold areas us a heater with a blower to move the air. Semi gloss paint takes longer when repainting for the simple fact that the paint has no where to absorb the moisture.
painting books can be very helpful
tverhoef is offline   Reply With Quote
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
What's your "favorite" tip, when using "oil base" paint? Bobrobert Painting 15 01-17-2008 11:36 PM
SW Duration paint - OK to thin with water? plin321 Painting 10 08-11-2007 10:29 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
