Paint Won't Dry - Painting - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 06:08 AM   #1
A/CMan
paint won't dry
Hi, I touched up some places on our cabinets and woodwork with some old paint that was left when the house was built. It is oil base enamel it looked funky in the can but I stirred it good and it looked ok ,looks good on the wood but it won't dry. It has been 24 hours and it is still tacky. Thank You, Howard ,T. Louisiana
A/CMan is offline   Reply With Quote
Old 03-26-2012, 06:56 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Sometimes the driers evaporate out of old oils.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Faron79 (03-27-2012)
Old 03-26-2012, 07:37 AM   #3
Too Short? Cut it Again!
I see you are from Louisiana. If humidity is already high that may be effecting drying time. I suspect the paint dryers may have failed as mentioned.
Old 03-26-2012, 05:20 PM   #4
A/CMan
Thank You, So do I need to take some thinner and remove the paint I put-on or do you think it will dry?
Old 03-26-2012, 11:01 PM   #5
NACE Coating Inspector
mustangmike3789's Avatar
24 hours is a long time for paint to dry. how thick did you apply it and how tacky is it. oil based paints need air movement over the surface to induce drying and a little solvent evaporation. if the paint if was applied too thick, it may never dry completly. we have found old puddles of 50 year old oil paints on bridge flanges that have skinned over but still liquid on the substraight kind of like opening a can of paint that has a skin on top but liquid under it. oxygen will cure the top layer of paint in the can and seal the rest of the paint from the air. you may be able to run fans of even a hair dryer to help drying. if this doesnt help, you may have to remove it.
mustangmike3789 is offline   Reply With Quote
The Following User Says Thank You to mustangmike3789 For This Useful Post:
Faron79 (03-26-2012)
Old 03-27-2012, 05:18 AM   #6
A/CMan
Thank You, I will try that and if it does not dry I will start over . I did not put it on thick and it does feel like it is drying some now. Thanks again
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
