Paint On Walls Not Drying Even - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 10:03 PM   #16
sorry, took so long to respond.......I ended up repainting whole room. did not re-cut... you can see a slight difference in color (not sheen). talked with a professional painter in the neighborhood, his opinion is that 1. the brand of paint and 2. second can was not mixed with same concentration as first.
to further frustrate me, my walls are still somewhat tacky to touch, and if anything is touching walls for any length of time, it sticks then peels all paint off right down to drywall. I will never use valspar again.
dcwarner is offline   Reply With Quote
Old 09-07-2011, 10:07 PM   #17
thanks for the input, sorry took so long to respond, I was loading my roller with lots of paint, it was dripping wet. the paint expert in my neighborhood, said the second can of paint probably was not mixed correctly, and that Valspar is not his choice of paint.. too many problems with it, one that I am experiencing is that my walls are still a bit tacky to touch and things stick to it if left touching walls for any length of time. lesson learned.... no more valspar
Old 09-07-2011, 11:03 PM   #18
DC, what color are you using, not the exact name, but the shade? Is it a greenish or goldish shade? The term is blocking (right on the tip of my tongue, thanks to Brush) which is the quality of the paint with regard to things sticking to it. Wouldn't be a good choice for shelving.
Old 09-08-2011, 06:28 AM   #19
Rubbin walls since'79
Brushjockey's Avatar
I'm still hunting for the best wb enamel with the least amount of blocking- at least one that you don't have to wait a couple of weeks cure time before it is reasonably usable.
I like Aura satin, but it has this prob, (to a much smaller degree than this poster).
Brushjockey is offline   Reply With Quote
Old 09-08-2011, 07:23 AM   #20
I like the waterborne Satin Impervo, dries hard, levels nicely for a latex and has somewhat of an oil finish look. Has a bit of a learning curve.
Old 09-09-2011, 02:30 PM   #21
The Impervo looks fantastic. I had to learn to really slather it on to get the brush lines to fall out well. The one drawback I found was that it forms a very rubbery sheet of paint than can peel very easily in large sheets ... even on lightly sanded surfaces. You might want to use a primer under it, or test a small patch.
BobSmitt is offline   Reply With Quote
Old 09-09-2011, 02:39 PM   #22
I used the WB imp before I use Aura- and felt aura laid out better and recoated faster. Both have a learning curve that has similarities and differences. And both need time to cure to be less sticky.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Old 09-09-2011, 07:16 PM   #23
I'd like to try the Aura semi for trim, but I'm just mastering the wb Impervo. Absolutely about the recoat time, WB Impervo is eight hours, but I cheat a bit sometimes. BM claims it is block resistant, and I've found it cures pretty hard fairly quickly.
Paint blistering and/or bubbling issues stro77 Painting 8 10-05-2012 11:59 PM
Commenting on Behr Paints athanman Painting 657 02-12-2012 04:21 PM
Sherwin-Williams Paint: Drying Time For Taping Twister Painting 10 07-16-2011 09:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
