Paint Walls Before Or After Hardwoods Installed - Painting - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 08:53 PM   #1
Paint walls before or after hardwoods installed
Paint walls and base broads before or after hardwoods installed?
Kdtiger is offline   Reply With Quote
Old 01-08-2012, 08:58 PM   #2
Rewards Points: 14,000
Always paint everything first. Why take the chance of getting paint on the floor?
Old 01-08-2012, 09:10 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I'm no moderator, but you only need to post the same question once. We'll see it.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-09-2012, 01:03 AM   #4
I always like getting all the mudding and painting done before any new finish floor goes down. If trim like baseboard is installed after the floor, then you can paint or second coat after installed, just protect the floor.
chrisBC is offline   Reply With Quote
Old 01-09-2012, 04:50 AM   #5
ARC Painting's Avatar
I find the best method is to do all the bulk of painting pre floors and trim. then final coats/ touch-ups at the end.
Assume trim and floor install will knick some walls!
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Old 01-10-2012, 06:53 AM   #6
My process is as follows
Prime and 2 coats of finish on the walls.
I prefer to prime, sand, and apply one coat of finish to trim that needs to be installed.
Install trim, fill nail holes, light sanding, remove dust with a vacuum followed by wiping with a damp rag.
Apply the final coat of paint and touch up any areas of the wall that may have been nicked during the trim installation.
CB Painters is offline   Reply With Quote
Old 01-10-2012, 07:00 AM   #7
I concur
I do the same on trim, then its cakewalk to finish the nail holes...
I also like the technique of wiping the filler over nail holes right away to avoid any sanding, works great. A sort of 'wet sanding', if you will.
Old 01-10-2012, 02:14 PM   #8
Just out of curiousity, how do you guys avoid the sanding, or do your "wet sanding" with the shrinkage of the filler?
Seems like everytime i've tried to do that I get shrinkage and have to re-fill before the final/touch up coat. So I will usually leave a bit of a build up and then sand it smooth, and will have to clean up the dust and wipe the trim.
special products, techniques?
Old 01-10-2012, 07:10 PM   #9
I use Dap's DryDex spackling with dry time indicator. Goes on pink and dries white. I find it very fast drying and I, like you, apply a small mound over the nail holes.
Usually by the time I go around the room and fill the nail holes it is dry and ready to sand, vacumm, followed by a quick wipe with a damp cloth. Then I apply the final coat of paint. Covers very well.
The Following User Says Thank You to CB Painters For This Useful Post:
chrisBC (01-10-2012)
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
Old paint on unprimed walls? Marmalade Painting 3 11-12-2009 04:10 AM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
