Which Paint To Use? - Painting - DIY Chatroom Home Improvement Forum
Old 07-29-2014, 09:20 PM   #1
Which paint to use?
I'm prepping my house and am looking for advice on a good quality paint but one that will not break my bank. I think SW duration is too expensive for me. I have block and wood gables. I used Glidden 15 years ago and it help up pretty well. Can you give me some suggestions? SW superpaint, A100, Glidden, Valspar Duramax??? Am I better off with a satin or semi-gloss?
Also, since my house is already painted do I still need to prime or just put a conditioner on the block? Last time I rolled a conditioner on.
dorlando is offline   Reply With Quote
Old 07-29-2014, 09:23 PM   #2
Gymschu's Avatar
Rewards Points: 192
SuperPaint
Gymschu is online now   Reply With Quote
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
joecaption (07-29-2014), ltd (07-30-2014)
Old 07-29-2014, 09:34 PM   #3
Rewards Points: 12,808
Super paint and proper prep.
No need for a primer unless there's bare wood showing.
Not willing to pressure wash and or clean than any paints going to fail.
Old 07-29-2014, 09:49 PM   #4
Painting contractor
Rewards Points: 341
Wash your house, not necessarily pressure wash it. A pump up sprayer of a 50/50 mixture of bleach and water and rinse with a hose will be fine.No need to prime unless you have bare wood or block showing where you scraped. Super Paint would be a good choice.Not sure what you mean by a "conditioner" for the block.As long as it's clean the paint is all you need.
Red Dog is offline   Reply With Quote
Old 07-29-2014, 10:00 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
I think they're referring to a masonry conditioner such as Seal Krete or Loxon. That's likely what I would use on the block. Primer on the wood if there's any raw spots.
Jmayspaint is online now   Reply With Quote
Old 07-29-2014, 11:12 PM   #6
Thanks for the comments. How about Porter Paint Acri-Shield? Is this equivalent to Superpaint? I don't have a $300k house and am just looking for a decent paint that will last 15 years or so.
Old 07-30-2014, 03:15 AM   #7
Porter Paints Acri-shield has a very good track record for us. We have used it for many years and it is a top performer.
Thomes is offline   Reply With Quote
Old 07-30-2014, 03:28 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
If you get 15 years out of ANY paint, you are ahead of the norm
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (07-30-2014), ToolSeeker (07-30-2014)
Old 07-30-2014, 07:03 AM   #9
Rewards Points: 5,974
Yes the Porter is good paint. Funny though where I am it's more than the super paint.
Old 07-30-2014, 09:26 AM   #10
Rewards Points: 4,780
FYI, that is bleaching, not "washing". It kills organisms and will appear to whiten the house, but that isn't the same as removing grime. That requires detergent, and in any case something to act as a surfactant helps even if you are applying bleach.
A pump sprayer is difficult if not dangerous to use over an entire 2-story house. That's why pressure washers are used - not to apply high pressure water to the surface, but to get the cleaner high up without ladders.
jeffnc is offline   Reply With Quote
Old 07-30-2014, 11:13 AM   #11
ok, so two questions. First, if I'm choosing between the acri-shield and power paint is it basically even? Can't go wrong with either, I live in Florida.
Second, as for the prep. Should I use a bleach and water option and also a separate washing with detergent?
Old 07-30-2014, 11:17 AM   #12
The bleach, detergent and water can all be combined. Do you have a 1 story house or 2? It will take you much longer with a pump sprayer than a pressure washer. Spray from the bottom up and rinse from the top down. Don't let the solution dry on your house before rinsing. This will be difficult because of how slow you'll be going with a pump sprayer, and how thin it will apply the solution. Let it dwell for several minutes before rinsing, but again without letting it dry. You might have to continue to apply to small sections at a time to accomplish that. You might want to pay the $150 or so to have it done.
Old 07-30-2014, 02:19 PM   #13
I have a 1 story house but with gables I have a friend who has a pressure washer so i will probably borrow it.
Old 07-30-2014, 03:19 PM   #14
In that case you need to use the detergent tip (usually black tip). After that, you either need to draw the solution through the pressure washer pump (usually not good for the pump), or you need a valve downstream of the pump that can draw the solution at full pressure. Otherwise you need an X-Jet. Otherwise, as I said, you can hire someone to do it for $150 or less usually :-)
Old 07-30-2014, 03:49 PM   #15
Painting contractor
Rewards Points: 341
I've done many 2 story houses with a sprayer in a half day or less."Bleaching" works fine for me.
My Review: Valspar vs Behr vs Olympic vs ColorPlace Achilles97 Painting 81 07-25-2014 05:51 PM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
